Are broken center pins a common occurance?
Discussion in 'The Garage' started by josh86k10, Jun 14, 2006.
  1. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    This makes my second or third broken center pin (in a couple of years, but then, my truck doesn't get driven all that often). I've recently been battling death wobble (added some washers, replaced my sloppy tie rod). Not quite sure if the broken center pin was a contributing factor to the death wobble or if the death wobble was a contributing factor to the broken center pin. One of those chicken or the egg type questions. Anyways, are broken center pins just one of those things that happens with a locker and 39.5's? How often do ya'll find a broken pin?
  2. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    I've broken the center pins twice in my front end locked with 39.5's. I use zero rates off centered so my center pins are less than an inch long. The reson mine broke is that they came loose, Im sure. You just have to loctite them good. I didnt use it before:doah:
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I broke one on the rear spring once. I really havent heard of it too much though.
  4. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I broke one when the u-bolts loosened up and I neglected checking them.:o
    Now I check them when I do other normal stuff like oil changes.;)
  5. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    the only time i have broke one is because my u bolts loosened up on me .
  6. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I have broken one. U-bolts were tight and all. not sure how it happened but it was while I was flexing right out with 33" tires and stock suspension.
