Are Chevy 75 C20 and GMC 79 C3500 rear assm. the same
Discussion in 'The Garage' started by stano, Sep 26, 2005.
  1. stano
    stano 1/2 ton status
    Jan 24, 2005
    130
    Iowa
    Are the rear end assm. (housing, axles, center section, spring perches) The same on a 1975 Chevy C20 3/4 ton (two wheel) 14 bolt and a 1979 GMC C3500 1 ton dually (two wheel). I figure the brake drum hubs, brake shoes, and the backing plate are different, but is the rest the same.
    thank you
    87 K5
    stano
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Is the 79 a cab & chassis or a pick up? If it's a pick up it should have a extra wide D70HD, if a c & c is should be a narrow 14 bolt.
  3. stano
    Jan 24, 2005
    130
    Iowa
    79 C3500 GMC is a pick up. Crew cab.
    75 C20 Chevy is a straight pick up
