Are D44 and 10B Front Spider Gears Interchangable?
Discussion in 'The Garage' started by GMCLegacy, Sep 27, 2003.
  1. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    Could i run 10B front axle shafts in my 44 housing if i swapped out the spiders?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    good question, i know 10b and d44 rear spiders arent interchangeable..
  3. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    Bummer, thanks for the quick reply confedneck
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    from other posts on here, i believe that the only thing interchangeable are the outter stub shafts, and anything else that's removable from the ends of the axle.
    rick
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Rick is correct. /forums/images/graemlins/thumb.gif
    As far as axleshafts go.....the stubs are interchangeable on 10 bolts and '73-up D44's. The inners shafts are different lengths.....so they won't work. /forums/images/graemlins/thumb.gif
  6. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    The spiders are the same between ford TTB D44s and a chevy D44... I know it isn't what your asking, but I thought that I'd share that little bit of info.
