Are hitch hook/shackles ok to use on the trail?
Discussion in 'The Garage' started by jakeslim, Mar 6, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    I need to install some tow points and am wondering if my tow hitch(rear) is ok to use with those shackle or hooks that just "plug" in.? /forums/images/graemlins/dunno.gif
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yep, great reason to have hitches fron and rear is the attatchment ability
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    do what i do and just keep the retaining pin and clip in your hitch instead of buying one of those shackles. works great for a yank strap. stick it in the reciever and put the pin thru. the plug in shackle might work better if your using a winch with a snatch block.
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    cool, that takes care of the rear..now for the front. I guess i need to drill and bolt some hefty hooks on the frame.
  5. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    As long as its a class 3 or larger its fine. I would get a insert and a clevis and not just through the strap in with the pin......Straps dont like it too much.
  6. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Too bad that won't work w/ some bigger straps. Also since the reciever isn't full the pin see more stress and is likely to bend. Have fungetting that out. Better to get the shackle and be prepared.
    Make sure you use a quality reciever hitch that is properly mounted.
  7. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    yeah, i will check to see all welds are good and strong. I can just see my hitch going thru the air now.. /forums/images/graemlins/tongue.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is BOLTS, not welds right?
  9. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    hmmm...let me check in the morning and confirm....
