Are International diesel engines good?
Discussion in 'The Lounge' started by 1985K20, Apr 22, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    We're getting a 330HP(low speed) International motor to put in our fishing boat...just wandering what the diesel people think bout them engines???
    Low revers(1700-1800 max rpm)
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Ford Powerstroke Diesels are International motors.
  3. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    Im talking about a 56000$ engine...about the price of a F-350 :D
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I think with a top end of 1700 RPM you better have one hell of an aggressive prop.
  5. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Are you fishing the lakes or the atlantic? IH made good tractor engines way back and some of those people are still there at IH so I wouldn't worry about it. How big is the boat? I'm guessing 45ft or more.....
    George
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Are you getting a 570? Now that is an engine! Those are torque monsters. Something like 1000 LBS at 2200 RPM . Would be great for a big motor yacht or trawler.
    How big is your boat?
  7. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    Our boat is 45 foot long,15 feet wide at the stern in a fiberglass mold with a thickness of 5/8 of an inch.
    Transmission is gonna be a Twin-disc 3 to 1 gear reduction...For the props im not sure but i know they gonna have some crazy diameter/pitch.
    Engine model:HT 570
    Specifications
    Engine Type Diesel 4-Cycle
    Configuration In-Line 6-Cylinder
    Displacement 570 cu in (9.3 liters)
    Bore and Stroke 4.59 x 5.75 in. (116.5 x 146.1.9 mm)
    Compression Ratio 17.14:1
    Aspiration EVRT Electronically Controlled Turbocharger, Air-to-Air Intercooled
    Governed Speed 2100 rpm/2200 rpm
    Combustion System Direct Injection
    Cooling System Capacity (engine only) 13.5 U.S. qt (12.8 liters)
    Lubricating System Capacity 32 U.S. qt* (30.3 liters)
    Total Engine Weight (dry) 1,560 lb (708 kg)
    Dimensions 45.1” L x 34.4” W x 40.8” H (1146 mm x 874 mm x 1026 mm)
    Performance Data
    Horsepower
    (bhp) Torque
    (lb-ft) Gov. Spd
    (rpm) Clutch Engagement Torque @ 800 rpm
    285hp 950lb-ft @ 2100
    310hp 1050lb-ft @ 2100/2200
    310hp 1150lb-ft @ 2100
    330hp 1150lb-ft @ 2100
    http://www.internationaldelivers.com/site_layout/engine/HT570detail.asp :)
