Are LS1 heads a direct bolt up? Never mind...I know they won't.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by travis, Dec 19, 2001.
  1. travis
    travis 1/2 ton status
    Nov 17, 2000
    173
    Panama City, FL
    Are LS1 heads a direct bolt up? Never mind...I know they won\'t.
    I've been looking on line for aluminum heads and it seems LS1 heads are pretty reasonable. Will they bolt right on and accept the standard accessories? Will the Performer intake work, what about exhaust headers? Valve covers? Any info would be great.
    Thanks,
    Travis
    <P ID="edit"><FONT class="small">Edited by 72Travis on 12/23/01 09:02 PM.</FONT></P>
  2. kansas blazer
    kansas blazer Registered Member
    Oct 16, 2001
    6
    Re: Are LS1 heads a direct bolt up?
    there is no way that LS1 heads will work because it is a completely different motor as far as block, heads, induction,etc. goes maybe you should go with some LT1 heads , that would be a better choice in my opinion because they will bolt right onto your motor without a problem and will accept all accesories and any intake you choose
  3. travis
    Nov 17, 2000
    173
    Panama City, FL
    I couldn't remember if it was the LS1 or LT1 heads my friend told me I could use. Thanks for clearing it up. I guess I should look for LT1 heads. Are the valve covers center bolt style? Do I need special rockers and push-rods?
    Thanks,
    Travis
  4. frito
    frito Registered Member
    Oct 17, 2001
    60
    fremont, CA
    uhmm you cant use either yes LT1 heads will bolt on BUT! LT1's have reverse flow cooling and the intake manifold mounting is differient than older small blocks the water pump on those motors are driven by the cam and unless you wanna do alota modifying to the head itself it wont work
    john lingenfelter got them to work on an earilyer SBC and said that the performance gains wernt great and the chambers of the heads are ver small 53 cc's vrs 76 for the heads you have right now prolly your best bed are L-98 corvette heads they can be had from a junk yard as cheap as 200 bux for the pair but their chambers are 58 CC 's so i hope your not running too high of compression
  5. travis
    Nov 17, 2000
    173
    Panama City, FL
    Thanks, I'll check into them.
    Travis
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    The LS-1 is a totally different engine family because it's corporate. It doesn't share anything with the Chevrolet engine other than the bellhousing pattern and motor mount locations.
    The other option that a few guys here have been trying are the Vortec Small-Block heads. I've read in the magazines that they're pretty good, but you will need a Vortec-specific intake manifold to make 'em work.
  7. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    Pick up the Feb. 2002 Chevy high performance. They bolted a set of vortec heads on a stock TPI motor, a new vortec tpi base, everything else sock, it produced 395HP. It has a couple of upgrade tests, with the end result being I think around 450HP, to lazy to find article. Check it out.
    Drive it Like You Hate It!
  8. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I almost went with the vortec heads when I did my rebuild. For the price ($450), they are probably the best cast iron head going. The bolt right up, have standard valvetrain geometry, and flow great. They have 1.94" intake and 1.50" valves and 64cc chambers. The only kinks are that you need a vortec intake to match the bolt pattern and they take centerbolt valve covers.
  9. travis
    Nov 17, 2000
    173
    Panama City, FL
    I think I'm going to stick with trying to find aluminum heads. I'm watching the papers and online for a pair I can snatch up pretty cheap. There's tons of LT1 stuff, that's why I wanted to find out what will bolt up. A cool idea would be a complete LT1 engine with the six speed tranny. I wonder if Advance Adapters has experimented with a kit to bolt up to a 205? Not that I could ever afford anything like that.....but you gotta admit, it would be cool.
    Travis
  10. Steve_Chin
    Mar 6, 2001
    1,126
    Travis, if you want a 6-speed, the New Venture 5600 is the only way to go in a Blazer. It's the "big sister" to the NV4500 that some of us have. The problem is that AA doesn't have a kit to bolt one up to a 205 yet.
