Are my automatic hubs gone or is it something else?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lehtola, Aug 11, 2002.
  1. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    The other day I noticed a little more strain on my drivetrain. I thought it might be an axle bearing. My U-joints look good. I have a little diff fluid seeping out or the rear so that was my suspicion on the rear-end. Should I be able to twist my front drive shaft around freely if it is in 2 wheel drive? I'm still not exactly sure what is going on. Been looking at prices for 14FF. Not ready to make the $$$ plunge right now. Can someone offer an opinion on what might be going on? The symptoms are as follows...
    While driving I experience a small amount of vibration accompanied by some noise. The noise is undetected unless I'm travelling at slower speeds. I've only driven a total of 12 miles since this has happened. The rear diff cover has some seeping. Not very much but enough to glaze the cover. It might have leaked a teaspoon total. Any ideas?
  2. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok, first off: what are you calling strain? vibe? or noise?
    [/ QUOTE ] vibe could be a tire out of balance, or a u joint going south, we need more symptoms, sounds like nothing major. is it brake noise?
    seeping isnt nothin to worry about, maybe need a seal or a gasket.
    yes it will move freely.
    14FF is cheaper to buy and fix than 1/2 ton cr@p!!! lookin at prolly 250.00 total for swap and mods ..
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    also, is the vibe front or rear, more details please....
  4. lehtola
    Mar 21, 2001
    192
    North Carolina
    It's a rear vibration...not like a driveshaft vibration though.
  5. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    if it is a rear vibe, why do you think hubs are gone in the front? /forums/images/icons/confused.gif /forums/images/icons/smirk.gif
  6. dyeager535
    26,975
    Shaft should move freely in 2wd of course.
    You do know that auto locking hubs require you to back up after disengaging 4wd right? Not assuming you are dumb or anything, but some people don't know this.
    Of course, in normal driving you will eventually back up anyways...
  7. wheelin72
    wheelin72 Registered Member
    Mar 6, 2002
    97
    Hanford, CA
    do u need to back up even on the new trucks?
  8. dyeager535
    26,975
    What do you mean new? "New" if you ask me means that the hubs are electrically or vacuum actuated, "Older" means the hubs lock in as you roll, ("automatic") and "really old" means reliable, and you turn them in with your fingers : )
    My '83 required you to back up, if thats what you are getting at, and I'd assume all Blazers up to and including 1991's required you to back up, if equipped with auto hubs.
