Are my u-joints bad?
Discussion in 'The Garage' started by Chevy305, Sep 7, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    So uh I guess ever since i took the truck to the 100mph mark, I have been hearing more pings and clacks than normal. They sound kinda like something metal hitting againt the drive shaft making that unique ping kind of noise. Also I have been getting some vibrations, pretty bad at times. Mostly accelerating in 3rd gear and some while cruising in 4th. I greased up both u-joints but it didn't make any improvements.
    Am I right to think this is u-joints? I have an extra u-joint (Brute Force). Should I just put it in and see how that works out?
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    wouldnt hurt to change them
  3. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    only one way to tell...
    I've changed U-joints that made NO noise whatsoever,and all one cup had in it was rusty DUST!...others I've had fail usually made a Errrrr--EEEEE--Errrrrr--EEEE-- squeak that gets faster as the truck gains speed,then makes it vibrate at highway speed...
    Your 100 mph ride likely didn't do them any good!--if your truck is lifted at all,U-joints only last a few thousand miles if you drive on the highway a lot..I only got 5-10 thousand miles out of the ones on my lifted K5 I had years ago,and the angles were not that excessive..I used cheap U-joints,because I soon learned even the most expensive ones didn't last much longer..hope thats all thats wrong in your case!..:crazy:
  4. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Maybe I should pull the diff cover too and see if I have any floating gear teeth...
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i doubt that
  6. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    Going 100 in a lifted truck huh? can you imagine what would happen if that front U joint failed at that speed. Wow. I agree with diesel4me. the ujoints might make a squeeky sound, and if they vibrate, you might try to move the driveshaft back and forth at the joint to see if they're bad.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The ping is an indicator . I had that , Marv said joint , and it was joint . Whatcha going 100 for in a brick anyway :thumb:
  8. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
