Are the Frames the Same???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5chevyblazer, Jul 3, 2003.
  1. k5chevyblazer
    k5chevyblazer Registered Member
    Jul 26, 2002
    5
    Sacramento, CA, USA
    I want to buy a 91 4x4 Blazer, and then take the 2wd front end out of a pickup and botl them in, so basically I want to make a 2wd 1991 Blazer, Are the frames the same, has anyone doen this?
    Thanks for the input.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    < just wondering why?
  3. k5chevyblazer
    Jul 26, 2002
    5
    Sacramento, CA, USA
    because i have a 73 that i take to the Rubicon, and i want a 2wd daily driver on air bags, i want the best of both worlds
  4. Confedneck
    Nov 1, 2002
    5,236
    that would definately be cool..
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The frame rails are the same shape, so it would be easy to pull the front axle & springs and mount the 2wd suspension.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    may have to drill some holes that may be missing for all the bolts and nuts to attach suspension engine cradle to frame rails, then deal with small stuff like brake hoses maybe lines too since they run across cradle
  7. Grim-Reaper
    7,385
    Atlanta
    It can be done. The rear spring mounts are also taller on a 4x4. Need to find 2wd spring mounts or go to a link suspension.
    If I ever build a 2wd I'll look seriously into a link set up. I want to make one that handles. /forums/images/graemlins/smile.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you start on the conversion yet >? hows it coming along ?
