Are the newer 350's good motors?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thatK30guy, Mar 23, 2002.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Are the newer 350\'s good motors?
    I have a chance to buy a '91 350 that has a bad bearing. Be a good rebuilder.
    I understand these motors are the one-piece rear main seals and the centerbolt valve covers.
    Are these motors desirable? Would it be worth rebuilding? Can I use an intake to adapt a carburetor to it?
    I want to use this motor to power the '82 K30 I got from Shawn. Just rebuild it to a good, strong daily driver.
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Re: Are the newer 350\'s good motors?
    Basically it is a 350... no real huge deal. Average internals, nothing special. The heads couyld be worse, but they definetly aren't the best of the bunch either. They aren't really desirable but they do make a solid daily driver core to start with.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    So, in your opinion, would I be better off finding an older motor or just use this one?
  4. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    IMO... if you have this motor or it is cheap, go with it. Maybe do a head and matching cam upgrade. A set of vortecs would be pretty nice for fuel economy and power, although if you wanna run cheap for a while just rebuild it and you can upgrade later if needed.
  5. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    If you look in the "Parts For Sale" forum I have an Edelbrock intake mainifold to put a spreadbore aka Quadrajet carburator on the engine you're refering to. There seems to be more aftermarket parts available for the old style engines, but I think that that will change after a while. I think that GM made changes to improve upon the old design, and it wouldn't be a bad choice.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure it's for an 87-95 style motor. They use a different (slightly) intake. Vortec heads are yet another different (drastically different and EXPENSIVE!) intake.
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    In stock form they are rated at 210 hp. with the tbi. There are tons of parts available for them. I would think it is a good choise.
