Are there 6 lug axles that are bolt on that are stronger than my 10 bolts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Dec 2, 2000.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I just bought new 6 lug wheels and I'd rather not eat them. Thanks
  2. Gold Rush
    Gold Rush 1/2 ton status
    1,498
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The Dana 44 and 10 bolt are about equal in strength, but those are for the front axle, which usually last longer than the rear because the yare not c-clip axles, and they are usually not turning, so they dont wear out as fast. There are some 6 lug 14 bolt SFs that can be found in heavy 1/2 tons and some Z71s.
    90K5
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    If you have a 30 spline carrier, then a 12 bolt axle will fit...you must gring down the nub end just a bit, but it'll work...I would contact Moser for their 1340H axles and see if they would grind them for you to the 10B length (I know it's just a couple thousandths)...I run 1340H axles in my 12B well worth the extra coinage...JD
