Are these good heads?? Supposedly 1.94 fuelers......
Discussion in 'The Garage' started by y5mgisi, Nov 12, 2004.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    The guy i got them from said they were 1.94 fuelers and they were in good shape so i picked em up. Any who the numbers are 8998993 and it has GM38 and the shape on the front of the head looks like this
    So are these actually good heads or did i get screwed? /forums/images/graemlins/ears.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    think you read the numbers wrong. there is no 8998993 as far as I can find, there however IS a 3998993 and they are [ QUOTE ]
    3998993....72-73...307/350......75cc chambers
    [/ QUOTE ] Sounds like your basic heads to me, probably not junk but I think you got screwed as far as buying what you thought you were getting.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Definatly not fuelie heads. All fulie heads have a double hump casting.Id numbers end in the following 3 digits 291, 461, 461X, 462 for the large hump(Early) heads.186, 492 small hump later model heads.
    Look like plain old early 70s and up large 76cc chamber 350 heads to me. They can have 1.94/1.50 valves. You can also find them with 2.02s
  4. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I have two books that say different things about those heads.
    Book 1
    3998993 = 1968-1976 350 1.71/1.5 truck
    Book 2
    3998993 = 1971 to present 350/400 1.94/1.5
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    they make good doorstops.
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I can tell you those heads are "hecho in mexico" it should say that somewhere on them around the valve spring area. They are nothing special, just 1.94"/1.5" 76cc chambers but early thick casting heads. These were commonly used on GM's target master engines made in mexico.
