Are these safe?
Discussion in 'The Garage' started by jamber2541, Nov 15, 2006.
  1. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    Are these safe and has anyone used one before
    [​IMG][​IMG] [​IMG][​IMG] [​IMG] [​IMG]
    Steel Leaf Spring Shims
    < BACK [​IMG]
    2-6 degree, $26.95
    8 degree, $30.95
    Applications:
    These shims are CNC machined from solid steel. They can be ordered in either 2, 4, 6, or 8 degrees. The center pin hole is 5/16 diameter. It can be drilled to fit any center pin size. These shims will not break like most aluminum ones.
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    good price imo. And as long as you bolt them into the bottom of the spring pack, they will work perfect.
  3. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I like those a lot better than the alum ones i have.
  4. SierraJim
    SierraJim Registered Member
    Nov 6, 2006
    21
    Eagan, MN
    I've got them, work fine.
  5. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    most people should have their springs shimmed if there are running a 6"+ lift
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Ummm... What? That is way to broad of a generalization. everyone should set up ther suspension based soley on how there rig is setup...:rolleyes:
  7. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    sorry wrong picture, I meant to post this up, I have shims on my 14b ff
    Dana 44 Spacer Block< BACK [​IMG]
    [​IMG]Steering [​IMG]Dana 44 Dana 60 ToyotaSteering Parts
    1/2" : $ 15.00
    1" : $ 22.00 Applications:
    Spacer blocks can be ordered 1/2 ” or 1” tall.
    1“ will require longer studs. If using "tall" steering arms, the 1/2" spacers can be used without changing studs.
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    I like the 1 piece arms better... because the 44 arms use cones... i dont like the idea of a seperate block.
  9. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    id rather spend the little more money on an actually lift steering arm..
  10. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    the reason I am asking is I have an arm, I originally went 6 in lift and now I am up to 8 inches of lift. whats the best way to correct this
  11. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    A 12 step program:haha::haha::haha:
    Sorry:o:o
  12. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    crossover and dont look back at the old push pull stuff. :wink1:
  13. goldwing2000
    goldwing2000 Guest
    Either that or get a drop pitman arm. That'll give you another 2 inches and save you a few hundred dollars.
    I would stay away from the spacer blocks. Mine had one on it when I bought it and I was getting movement between the arm, block and knuckle, no matter how much I tightened the fasteners.
  14. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    thanks a bunch, start looking into crossover steering it is
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    x a million...crossover is the only way to go:D
  16. goldwing2000
    goldwing2000 Guest
    Well... if you have a bunch of money lying around, it is.
    Us poor folk have to stick to cheaper mods. :dunno:
    Crossover setup: $500+
    Drop Pitman Arm: $95
    Besides that, if it's a DD rig, crossover will give more bump steer.
  17. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Wrong, not on all rigs. When I did crossover on my burb, it cured a lot of bump steer.
  18. goldwing2000
    goldwing2000 Guest
    :dunno: I'm just going by what I've heard.
  19. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    other than price i cant really think of any reason not to go crossover.
  20. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I wouldn't use a spacer block, I have seen them used and the bolts or studs that hold them in tend to break. They seem to break one at a time you go from "my steering feels a bit funny" to " something is wrong" pretty darn quick.
