are we out of plumbers now?
Discussion in 'The Lounge' started by ryan22re, May 4, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    what do you all think of those compression fittings they use for plumbing these days? ive got one under the sink that keeps coming loose.
    what can be done to fix it? ive replaced the gasket and tightened it up more times that i care to remember.
    should i replace all of the compression fittings with regular pvc pipe and glue?
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Yep,,,Plumb out...
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Just make sure they are male/female and not male/male.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    i thought it was ok for female/female too right?
  5. Cricket
    Nov 29, 2004
    8,224
    Colorado
    As long as you place them at a 69 degree angle. :D
  6. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    And try to use to some gel to make sure it's a tight fit.
    I know sometimes it can be very challenging to find a male large enough to completely fill the female gap:haha:
  7. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    And if the fit seems a little snug, just spit on it.........
    John
  8. icedragon
    icedragon Registered Member
    Sep 6, 2005
    18
    connecticut
    ryan
    are these pipes teh old chrome or brass drain pipes? is there a nut at the wall? if so change to all tubular pvc, not regular pvc thats too thick. use some teflon tape on threads jsut a wrap or 2 everything should be fine then. find your local plumbing supply house and check with them they should be able to set you up.
    Rich
