ARE WHEEL BEARING RACES SUPPOSED TO MOVE?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by purple89jimmy, Oct 7, 2001.
  1. purple89jimmy
    purple89jimmy Registered Member
    May 29, 2001
    75
    Please help. I am repacking my front wheel bearings when I noticed that the inner race on the front driver side spins inside the wheel, but the outer one does not. I tapped it out and looked at it, but it doesn't appear to be damged or worn in any way. Please respond, my buddy said that I would have to but a new rotor. I have my front tore apart and I am awaiting your guy's input before I make any decisions to buy a new rotor or put in a new race. We measured the outside of the old race and a new one and they are the same, ie no wear on the outside of the old race. It is an 89 10 bolt
  2. scooby
    scooby Registered Member
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    no they are not supoesed to move replace it.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    No they are not suppose to move. You can try to make the race stick by taking a punch and hitting the rotor where the race is suppose to stick. The punch marks wil make little high spots so the race can grab onto them. Make between 10 and 15 all the way around. If that doesnt work then you will have to buy a new rotor.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. scooby
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    if the rotor surface is not damaged, you dont need to replace the entire rotor , what u need to do is replace the race they are sold induvidualy. please do not use a punch to put " high spots" this will only cause u probs down the road.
    " use the right tool for the job"
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Using a punch is no problem. Go take a look at any of the shops out there. Thats what they do to make sure the races stick. But I personally wouldn't do it if the race can spin. That is too loose. But it would get you by in a pinch. You can try a new race, but if that doent work then you need a new rotor.
  6. scooby
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    desert,
    you are 110% corect :))
    darn were good :))
    " the thicker the mud, the slower u sink "
  7. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i must be slow
    what kind of vehicle are we working on?
    if it is a 4x4 the rotor should be fine.
    the HUB sounds pooched
  8. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    The races are in the hub, the rotor goes on the hub. Buy a new hub or pick one up at a salvge yard. The rotor is held to the hub by the wheel studs, if you buy a rotor it won't solve your problem. Absolutely replace, it is not safe driving with that race spinning in the hub!
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  9. dragricinMT
    Jul 21, 2001
    135
    Billings Montana
    73 Vega 350SB TH350
  10. purple89jimmy
    May 29, 2001
    75
    Well I punched the race race journals and the races seemed to stick. I just put in timken bearings and races so maybe that will hold me till somebody sells me a 14bff/D60 combo. Thanks for your advice you guys are great.
