are you kidding?!
Discussion in 'The Garage' started by reaper450, Mar 23, 2007.
  1. reaper450
    reaper450 Registered Member
    Jul 4, 2006
    21
    ohio
    Started kicking around the idea of putting on my body lift the other day, so today I go out to look at where the body mount bolts are located at. Found the back two pretty easily, they come right up through the bed, and the front two are easy as well, but where the heck are the two sets in the cab? I got to thinkin that when I replaced the floors i never saw the bolts through the floor pan so I hate to ask... :crazy: are they under the floor in the brace that runs across the floor? And if they are is there any way of getting the bolts out without cutting the floor board? :confused:
  2. dyeager535
    26,980
    The front cab ones as I recall, are "captured", they use those e-clips that tend to rust out. :(
  3. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    few problems here. first what are you working on? blazer / pickup / burban? and what year vehicle?
    second you need to look under the truck and see that the 4 main bolts for the cab on atleast a pickup truck feed up threw to the body. then the 2 frt coresupport bolts are feed down threw the support and have a nut holding the bottom side. this will require the grill to be removed.
    the nuts arnt speed nuts. thay are big square nuts almost 1/2 inch thick and are captured by to big tabs folded over in the body support area. if you need to ever get acsess to the nuts you will need to cut threw the floor and the inner floor in that area. i had to do this its no big deal. just measure twice and cut hole once. then when done tack weld the piece back over it.
    this is not as bad as it sounds. but if you have a good amount of rust or thay use lots of salt in the winter time on the roads. best start spraying the stuff with real goot penitrent lube like p.b. blaster or other. but not liquid wrench or wd-40 thay just lube. you need a "walking" penitrent lube rust buster.
    hope this helps and gve us some more info to help you better.
  4. reaper450
    Jul 4, 2006
    21
    ohio
    it's an 82 k5 blazer. So the cab bolts just unbolt unless the tab is rusted, at which point you have to cut through the floor to get the nut out. Am I reading this right?
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    YES.
    every older truck I have done a body lift or bushings on I have had to cut into the floor. It's not a big deal. I dont even measure anymore. if you can't see where to cut from the welds on the floor you can give the floor a good whack with a big hammer in approximately where you need to be and the pocket will reveal itself.
  6. reaper450
    Jul 4, 2006
    21
    ohio
    see, thats kind of what i want to avoid considering I just put a new floor in it not 5 months ago. So if I don't have to cut I'd rather not. Also, The kit came with a pin to extend the shift linkage. Are they talking about the actual shifter, or the rod that goes from the tranny to the t-case? Or something altogether different? Thanks for the help guys.
  7. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    the column shift linkage may need to be extended if there is not enough rod left to adjust for the body lift. how high are you going?
    the linkage for the t-case should have enough to only adjust it. the rod is mounted horizontally so the height change does not have as big an affect on it.
  8. jpdrake
    jpdrake 1/2 ton status
    Oct 31, 2005
    381
    mass/ cape cod
    this is the drivers side then 2 in radiator and 4 in the bed
  9. reaper450
    Jul 4, 2006
    21
    ohio
    it's goin up 3". Went out and dug around on it a little more and found and obstacle. One of the very back bolts is pulled up into the bushing, the best way to fix this is by just grinding the top of the bolt off and pushing it through the opposite way right? It's in there far enough that you can't get a wrench on it.
    Is the rod that needs lengthened the one between the clutch pedal and the clutch fork. And if it helps in your answers of what to do I do have complete access to a welding/machine shop with the knowledge to do it, so the possibilities are endless... at least i hope...
  10. sweetk30
    Nov 1, 2004
    25,546
    542
    you need to slot the hole in the flor and lengthen that rod from the pedel in the cab to the z bar on the frame rail to block piviot. most guys use threaded rod and make a new one so its fully adjustable for fine tuning the system.
