are you like me/not 1 upgrade ever goes right??
Discussion in 'The Garage' started by RootBreaker, Jul 29, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    you know murphy is so dayum old that he needs to kick the bucket :crazy:
    other than all my past upgrades that all took alot of finess due to stupid crap that never works right..... it doesnt stop...
    so now I put my new column in... 85 in a 78..... high beams and wipers on column work... :wink1:
    washers and horn dont :doah:
    not a biggie... washers are on a switch and who needs a horn when your tires hum louder than a locomotive :haha:
    so I did the hydraulic clutch conversion.. other than taking 4 nights to try and get the tranny back in all went I guess ok.... however bleeding this biatch is not going good.... my old mechanic finally said... you push the pedal down... hold... crack bleeder... then close bleeder... let pedal up and push down and repeat steps.. do not pump... so I did this last night and alot of fluid (no air from what I saw or heard) came out.... well get in truck... start it up.. and try and put in gear..... will only engage if I MASH the pedal to the floor and slam it into gear.... let clutch out and it engages within 1/4" of releasing the pedal :doah:
    Is that right????
    so anyway I was going to get gas since it was low..... put it in gear and turn on the headlights... well I had the door open and the interrior light went off.... I was like... huh.. oh well..... but then realizing my fuel pump was not on... loud chattery type ..... she just died.... :eek1:
    so got under the dash and looked around.. jiggled the entire wire harness and the light came back on... truck wouldnt start and I still couldnt hear the pump... so I took the pump out of ignition and put it into 2 other ignition spots...no go.. put it into battery.... well viola... got fuel pump back...
    oh yeah all my gauges stopped working... not one...
    volt meter is pegged down below 8, oil psi is in the middle, fuel gauge is at 1/2 with full tank, temp pegs past 260 degrees....... they all worked before I changed the column and clutch
    if it aint one thing it is another.... this is driving me crazy!!!!!!!!!!
    so tonight im going to cleanup the garage some.... pickup all my tools and cleanup the hell hole of a mess from lifting a 1998 4 door blazer in my driveway last weekend..... then tear the harness apart and figure what the hell happened... wonder if it would have anything to do with the column??? but doesnt the ignition parts of the fuse block feed from the starter????...... :doah:
    with my winch on the way it would be nice to get something done right!!!!!!
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Thats why I love not having to drive mine everyday, I had some problems fixing a little rust on mine last week and said hell with it and parked, got out my table saw and started doing some wood work. Mayby thus weekend i will finish the patch panels and get it ready to be caged and full topless but its nice to have another hobby thats relaxing too.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    What fun would it be if it went right the first time? I thought that the first time was a run through so you could figure out how to do it right on the third time. It is much easier when you are not working on your DD.
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    oh yeah added this too
    maybe I should have stayed with the old column and mechanical clutch linkage that wasnt working right??????
    to everyone else what I do is considered and upgrage... do me it is a downgrade....... :doah:
  5. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Try this..
    Clamp the clutch fork in place to the bellhousing then push the pedal down and crack the bleeder..
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    huh??? so the slave cylinder piston part that pushes the clutch fork should be in our out?
    thanks :bow:
    Jeff
  7. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    haha, i know how you feel.
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    I was just thinking god forbid....
    anyhow.. when I put my starter back in.. hooked up the negative battery lead.. the truck started to crank over.. seems that the fuseable link on the small wire on the starter has bare wire showing on both ends... so moved it and that problem went away...
    however... isnt that the ignition feed? the truck starts and drives fine...
    also I have a wire in the fuse box... old ignition wire that stopped working and we cut it and put a new wire in.... well I think that may have become hot after I jiggled the fusebox again... may have blown a fuse or even the fuseable link...
    that would make sense.. as I lost all 3 ignition parts on the fuse block and also NO gauges :doah:
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    What are you complaining about? That upgrade went smoother than if I were to do it with fewer problems....
  10. senatorwoodhouse
    senatorwoodhouse 1/2 ton status
    Jan 22, 2005
    108
    des moines, IA 50311
    hmmmmmmmmm, that sounds familiar........... :haha:
  11. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Anytime I've install something with no problems, I go back and look for problems or wait for something to fall out.
  12. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    happens all the time to me. this one time all I wanted to do was change out the rear bushing to greasables, someting that should of taken a day or so ended up being 3 weeks :eek1: it's just part of the game.
  13. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    LMAO heck yeah im the same way. the one time it went smooth- i stood there drinking a beer and scratching my head trying to think what i forgot to do, SOMETHING has to be wrong. turned out was ok - still waiting for my front u-bolts to pop of or something :doah:
  14. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    by the way, they make a nipple u can replace ure stock one with that u just crack open and it alows fluid out and no air in. so just pump and keep checking fluid
  15. RootBreaker
    Nov 29, 2001
    5,117
    173
    where do you get this and part number?
    thanks
    Jeff
  16. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i got mine from autozone self help isle, replaced all mine with them-love em :D
