ARGH more tranny problems
Discussion in 'The Garage' started by stockk5, May 5, 2006.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Well more of the same problem, my tranny pan was leaking so i dropped it down got a new gasket.. the rubber one from napa and cleaned everying spotless, used some brake cleaner cleaned off any oil dried both sides and put it back up there, made sure i didnt over tighten anything and bam it leaks again, only from the back right corner of the tranny pan on my 700R.. Would it be ok for me to drop it again, re-use the gasket and put a lil bit of rvt sealant in there? I dont wanna drive it cuz after about 2hrs of it parked there is a 2ft dia puddle from it under the truck. The pan seems to be level and straight so i dont know what is going on. Any ideas on how to seal it?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    have you tried tightening the bolts a little more?
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    don't use RTV on a tranny pan that is a big nono, RTV can cause you more problems than you allready have
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    are you sure its coming from the pan? or could it be from the rear of the trans. has the pan in the past been over tightened and warped?
  5. dyeager535
    26,982
    190
    Back when I had no money, I reused the rubber pan gaskets a few times. I always ended up sealing them with a THIN layer of RTV on the pan. (because that is the easy part to scrape it off of) I'm talking a *tiny* bit on my finger, smear it on only down the center of the pan rail, and around each bolt hole.
    I know it's a bad thing, but when you have no money, and it leaks, you do what you have to do. Besides, whats the filter for? haha :)
