Argon or CO2 for mig gas
Discussion in 'The Tool Shed' started by 8_YOUR_H2, Apr 20, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Is there any difference between using argon and CO2 for mig gas?
  2. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    usually its a mixture. Running pure Argon is not recommended for mild steel, it has shallow penetration and bead looks crappy. People usually mix the two. 75/25 % and so one depending on what you like.
  3. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I hear ya, I had a little SPL 135 a few years ago and used the argon blend. I am just wondering if there are any benefits to using a blend over CO2 or visa versa, maybe it is cheaper?
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    co2 is the cheaper of the welding gases... its all we use at school... but for my personal welding I like a 75/25 mix... (ar/c02)... and with my powermig in power mode or spray arc it likes 85/15 even better... the mixes are WAY more expensive but do have less spatter and smoke then straight co2
    cam
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Usually need better than 90% Argon to get spray transfer...we run 92/8 at work. For my home rig I use 75/25 (Millermatic 135) and it runs nice with tolerable spatter if there is such a thing.
    Straight Argon is mostly used for aluminum Mig, although I prefer an Argon Helium mix.
    Rene
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Straight Co2 burns hotter so it is nice for a small welder, I have a pro mig 135 and run straight Co2, very happy with the weld quality but I dont think it has enough power to weld much over 1/8".
  7. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thats the nice thing about the new powermig... its much more forgiving on percentages... and the computer makes a good weldor... well.. skill is skill but it really helps produce machine automated looking welds in the manual mode....
    Welding thin aluminum before with a spool gun meant super fast speeds and still there was a chance of melt thru,,, now I can weld fairly light guage... 16 lets say... no prob... I have the python push pull gun..which is large.. but Ill rarely weld any aluminum under 1/8,,,, the weld quality and appearance is just flat amazing... miller isnt even in the ball game yet
    I still have tig (squarewave 185) for slow intricate welds... I might use it for an exo cage where spatter might be a problem if I didnt want to, or couldnt, cover the area with a welding blanket (you get very little with double pulse)...otherwise its double pulse with the powermig everytime now
  8. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    For aluminum we use the Miller XR-W Control push-pull feeder with water cooled gooseneck gun coupled with the Optima MIG pulse control programmer. The Coolmate does a fine job of keeping the gun cool. We do aluminum from light guage to 1" thick...although we usually use TIG for the light stuff.
    Personally I don't like aluminum, although i'm decent at it.
    This is our TIG machine, and is the one I spend the most time using. :D
    http://www.millerwelds.com/products/tig/syncrowave_250_dx/
    Rene
