Arizona State Land Recreational Permit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by marv_springer, Mar 26, 2002.
  1. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Attention all Arizona Wheelers!
    I've heard more reports of people receiving citations out in the General "Florence / Jamboree" area. I just plunked down $20 for a permit today. FourWheeler's Supply on Washington St has them or call 602-364-2753.
    I've heard the fine is $500..../forums/images/icons/shocked.gif
    Marv
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    How long is the permit good for? Not that I will be wheeling for a while, but when my new project is done.
  3. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    1 year....
    Marv
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Hey Marv, Is that permit for one vehicle or person?And is it good in all the state?I never heard of such a permit.I guessing I better get one quick!!!!BTW could you read my post on 56" springs?Thanks Mike
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The state land permit is per owner/vehicle (atleast per the original idea - passengers don't need a seperate one), and is good for state trust lands across the board. It really is a good program - much like a fishing/hunting license, the money goes to conservation efforts, fire suppression, etc. For $20 you can help insure that state lands stay open to access.
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    A hunting license still qualifies doesnt it?
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmmm, if I'm going this week end, I guess I'll need to get one? Not sure if I will or not. I've been having trouble finding a machine shop that will open up the taper in my pitman arm and drop a few holes in my offset plates. I did find a place that I can buy a piloted counter bore for $30 so I'll probably just do my own holes. No luck on the tapered hole though. Without that fixed, I have no steering and I won't be able to go.
    BTW, do you think my locked in the rear, open in the front, bed-less LWB on 42 will be able to run with you big dogs on Friday? Or is this out of my league for a "maiden voyage take two" (first one washed out when I blew a fuel pump but didn't realize that was the problem).
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Russ I will see if I still have the drill bit to drill tapered holes. I had one but I think I left it at work, and I dont work there anymore, and cant get it (long story). I will look tomorrow.
  9. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Russ,
    ... you gotta make it man...! If you want, I'll tow you out or lend you the pitman arm off my FunBuggy!... It has a straight drilled 3/4" diameter, but we could make you a drag link to use a heim joint on that end.
    42's and no body to dent is the perfect recipe...!! Just ask NoRulz..! You guys w/ 42's ARE the "Big Dogs"...!
    Marv
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Thanks much for the offer. Looks like I may have it worked out. I'll let you know...
    Hmmm, now that it's warmed up, I think the doors are going to disappear too. Then my "body" will consist of a cab, hood, and core support. /forums/images/icons/laugh.gif
  11. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Where are you planning on running on Fri. Marv?
  12. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I don't think so - I was told that the land department was getting absolutely zero funding from game and fish or state parks and is trying to recover from Hull's budget cuts. I've got a buddy that's a spervisor with state land, I'll give him a buzz and find out for sure.
  13. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    We are going to run "Upper Ajax" which is out in the general "Florence / Jamboree" area. See my other post titled "Got Friday off - Let's go wheelin'"....
    Would be great if you made it!
    Marv
  14. bigdaddy89
    May 18, 2000
    422
    Phx, Az
    Yeah I saw it after I had made the post. I was hoping you would be going upto Table Mesa area.
  15. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    The weekend of April 13th... I think we're gonna go do Lower Terminator. Who knows, maybe we'll have time for another trail too!
    Marv
  16. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    OK, Per ASLD, the rec. permit is necessary when running state trust lands other than when hunting or fishing. Personally I don't mind plopping down the $20, since it takes away from the enviros' ability to complain (and I can easily make it back from ASLD in a couple of hours during the fire season/forums/images/icons/smile.gif)
  17. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Where can you purchase the permit?
    Azblazer
  18. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    The top says 4 Wheel Supply on Washington and 32nd St /forums/images/icons/smile.gif
  19. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Awwww, crap! I was so busy getting the rig ready, I forgot to go get a permit! My luck I'll get busted after all that work... /forums/images/icons/frown.gif
  20. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    To my knowledge it's been farmed out to the offroad shops, and you can pick one up at any ASLD office.
