army M1009 and differentials questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by domator, Feb 20, 2001.
  1. domator
    domator Registered Member
    Feb 20, 2001
    12
    Poland, Europe
    Hi,
    I recently bought '86 Chevrolet M1009 and now I'm checking what it realy is.
    1. I have big mess in my mind concerning axles and diffs. The army manual says it has rear locking type differential. Is it gov-lock ?? And what does it mean in real life? Is it good option?
    What about highway driving with this gov-lock?
    2. I understand that these truck doesn't have central diff and when it is 4x4 it means 50% of torque goes front and 50% goes rear. Am I right?
    Thanks for all answers - here - in Poland - we don't have these cars and it is really difficult to find any information :-((
    Piotr
  2. dyeager535
    26,979
    Since they are half ton axles, I don't think at that time GM used anything BUT Gov-Locks. So you would be safe to assume yes, it is a gov-lock. Jacking up the rear end, and spinning one tire will tell you. If it is an open differential (not locker or posi) OR a Gov Lock, the rear wheels will spin in opposite directions, if you spin them by hand slowly.
    On the S-10's with Gov Lock, if you spin the one tire fast enough by hand, you will feel it lock up.
    There is no problem running these on the highway, as long as you don't like doing burnouts and such. Driven conservatively, it should give you no problem.
    Yes, there is no center differential. 50 front/50 rear. The driveshafts are physically(mechanically) locked together, unlike AWD and the like that use fluid coupling.
    Dorian
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Yeager is "on the money". It is a gov-Lock, front & rear axles are 10 bolt GMs, transfer case is NP208 part time four wheel drive.
