*&($@#!^%$!@#$ ARRGGHHH!!! DAMMIT!!!!
Discussion in 'Pacific Region' started by Zeus33rd, May 16, 2002.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Just got done changin out the oil pan gasket on my rig....Started it up and let it idle while I went inside to get somethin to eat. When I came back outside there was a huge puddle of ATF on the driveway......In the process of pullin the pan off, I somehow kinked one of the tranny cooler lines, breaking it. ARGHHHHHHHHHHH$#@!(*&_!#@*$
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Damn dude!! You are full of issues ain't ya!!
    So if it wasen't for bad luck I take it you would have no luck at all??/forums/images/icons/smile.gif
    Hang in there it is all gonna work out someday.........../forums/images/icons/crazy.gif
  3. LiftedAssDodge
    LiftedAssDodge 1/2 ton status
    Apr 8, 2002
    412
    East Bay Area, ca
    between this and the whole forgetting the axle thing i dunno if you should be workin on it haha
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Well, I just pulled it off and replaced it today. It turns out it wasn't really my fault. The old line had been rubbing against something that had worn almost alll the way through. When I pulled the oil pan out, it tweaked it just enuff to put a hole in that paper thin section of tube. I don't feel quit so retarded now. /forums/images/icons/smile.gif
  5. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok here is my goof...
    I go to pull the vaccume line off the carb to set the timing and guess what comes with the tubing .................................................................................................................................... the frecking metal tube that goes into the base of the carb so it is now the epoxyis drying over-night so I can finish the timing in the morning....mike/forums/images/icons/mad.gif
