Arrrgghhh!!! I hate these $%#&ing hubs!
Discussion in 'The Garage' started by steelsoldiers, Feb 10, 2004.
  1. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    OK, I still can't get the hub body off of my M-H axle. They are MileMarker Selectro hubs and they have an aluminum base. The aluminum has seized to the steel wheel hub and will not let go. I have tried everything. I have pried on them, beat on them, cussed at them, soaked them in oil. Last night I had a brainstorm, I cut some threads in the smooth holes of the hub body, put a piece of steel rod down in the hole, then threaded a larger bolt in on top of the rod to push against the bottom of the hole and pull the hub body away. I think it may have budged ever so slightly, but then the threads would pull out of the soft aluminum and I would have to tap the next one. I went all the way around the hub doing this and still no go. I am about to the point of just destroying the mutha%$#@er just to get it out, but I hate to bash a pair of decent hubs. Anybody have any thoughts? I am open to just about anything at this point. Thanks.
    This is the one that is still together for reference.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Is there a way to heat the steel some with a torch? This should help to free the seized aluminum hub base from the steel wheel hub. If not you may have to cut them out /forums/images/graemlins/yikes.gif good luck /forums/images/graemlins/thumb.gif
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Heat and quench, heat and quench. That is a good way to get it loose, just not so hot it warps or treats the metals. I am a fan of a hammer over a torch myself.
  4. steelsoldiers
    Oct 17, 2002
    365
    So you guys are saying it's time to break out the rosebud and a bucket of water? That should be fun tonight. The wife's going to love it. The house will be filled with steam that smells like PB Blaster. /forums/images/graemlins/doah.gif
  5. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Well the aluminum will expand differently than the steel. It should not take much of a change to hot pop it loose.
  6. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    A good overnight or two soaking with Parts Blaster (PB) has always worked for me.
    Good luck.
  7. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    did ya get the hub out?
  8. steelsoldiers
    Oct 17, 2002
    365
    I sure did. I mentioned it in my other post but I forgot to in this one. Here a pic of the hub body:
    I finally had a good idea after I broke part of the hub /forums/images/graemlins/angryfire.gif Oh well, they were pretty corroded anyways and probably would have let me down at some point. I actually drilled and tapped a hole in between two other holes, threaded in a bolt, and then kept cranking which forced the hub away from the axle using the end of the bolt. When it finally came out I felt like I just won the lottery Who knows what the next challenge will be with this thing. I guess that's part of the fun of using a less common front end /forums/images/graemlins/yikes.gif
  9. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Good idea, keep us informed on your progress /forums/images/graemlins/thumb.gif
