Articulation
Discussion in 'The Garage' started by dammit32, May 23, 2003.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I dont think my K5 will ever do this :
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Nope, it will never have a horrifying rear steer effect due to short links like that does. </font>
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    my suburban will one day have that rear steer "problem" due to a D60 and a full hydro set up.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I don't quite understand how a D60 and hydro will cause the rearend to steer as though it has a 4 link with very short links, but OK. /forums/images/graemlins/tongue.gif It looks like the rig in the pic does have rear steering, but the axle is also far from square, the side that is drooped is much farther forward than the side that is stuffed, that's the problem I'm talking about. Rear steer in the traditional sense is the shizzle for rizzle. /forums/images/graemlins/laugh.gif /forums/images/graemlins/wink.gif</font>
  5. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    It looks broke.
    Jim
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Sure your K5 could do that...just remove all the shackle bolts (and don't drive it on the street/forums/images/graemlins/grin.gif)
    Rene
  7. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I think he may have meant 4 wheel steering with full hydro Shaggs...
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah but Shaggs and I are talking about the rear axle steer caused by poor 4 link design.
  9. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I can only dream.... /forums/images/graemlins/shocked.gif
  10. FULLSIZE
    FULLSIZE Registered Member
    Aug 8, 2002
    76
    it does appear to have rear steer(the suspension), but its an optical illusion caused by the turned wheels. jason paule is one of the premier buggy builders in the country. his 4 links stay very square(as much as humanly possible) in the chassis. i have seen some horrible 4 links that turn the rig enough where the driver has to steer into it. /forums/images/graemlins/ignore.gif
  11. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Looks like the things got a tie-rod and knuckles to me.
    If it doesn't, then....um...
    Yikes !
  12. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    it does almost look like theres a tie rod and knuckles but the axle is still 90* to either wheel ruling out rear steering there. Looks kinda scary /forums/images/graemlins/eek.gif
  13. NE-RokToy
    NE-RokToy Registered Member
    Dec 24, 2002
    39
    Omaha NE
    You do relize you are trying to bash a builder who has had rigs take the top three spots at a national event not to long ago?
    I agree that the rig has some suspension induced rear steer but not a whole lot, I have alot of pictures to bad I can't post them. Also flex steer isnt the worst thing in the world expecially when you have rear steering. Many other things have to be taken into account, such as ground clearance and roll center along with flex steer.
  14. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I'm sure that might be the case when your creeping along at a snails pace. But, I would suspect, it would be handfull to control, at any speed.
    Preditcability, is overrideing in my opinion.
    I'd gladdly give up some articulation, in favor of "knowing" how the things going to react to the tarrain. If the rear axle steers, by more than a 4 or 5 deggrees. It's going to take the driver's mind off the path ahead, and place it in the path behind (possibly, literarly).
    In this case, rear steer (as often is the case) works in favor of the driver. The drive would not have to over-steer the corner, as he would have if the rear steer was limited.
  15. FULLSIZE
    Aug 8, 2002
    76
    this is why high speeed desert trucks use 2 link suspension that has like 4'+ long control arms and anti-roll bars. /forums/images/graemlins/wink.gif
  16. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Uh-huh...
  17. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Uh-huh...
    BWAHAHAHAHAHAHAHAHA!!!! /forums/images/graemlins/thumb.gif
  18. FULLSIZE
    Aug 8, 2002
    76
    Uh-huh...
    .................... what did i miss here? /forums/images/graemlins/ears.gif
  19. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Uh-huh...
    Ummmm I dont think a 2 link would work really well. What in the hell is going to locate the axle side to side? BTW they usually use 3 or 4 link designs, a 2 link just wouldnt work at all.
  20. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    Two long trailing arms and a panhard bar (not tech a link) would be a 2 link, but I've head it called that. Most folks around here say "It's got Chevy truck trailing arms" refering to '72 &amp; older 2WDs.
