As anybody done a right up on..
Discussion in 'The Garage' started by gokartergo, Feb 17, 2004.
  1. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Replacing power window motors.. I read through the Haynes manuel.. But I now you guys now some shortcuts.. I took off the door panels today and it looks like a pain in the arse.. Specialy when the windows are stuck in the closed position... Thanks
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    yea if the windows are stuck down ur screwed. you need to get them up somehow to get the motor out. Its also gonna be kindof hard to get hard to get in there if youve got big arms.
    Nick
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    my write up would be.... Remove electric window stuff, Replace with manual window stuff /forums/images/graemlins/waytogo.gif
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Closed I mean up position.. If they where in the middle it seems it would be easier to get the windows out..
  5. unick
    Aug 16, 2003
    4,286
    I took mine out with it in the up position. It wasnt that hard. The hardest thing was getting at the right angle with my arms in the door.
    Nick
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i ended up cutting a few pieces of metal out of the door so i could get in there easier /forums/images/graemlins/rotfl.gif
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I probley done mine the long way but I was also replacing the weather striping around the glass...
    pull off door panel, roll window down 2-3inches, unbolt glass from gears, slide glass out, unbolt every bolt on the inside of the door, contort arm into Z shape and disconnect wiring from motor and locks, push harness aside, pull/fanaggel scizzor gear with motor attached out, drill rivets, replace motor (after testing it to make sure its all the way up or all the way down matching the position of the one you pulled out /forums/images/graemlins/waytogo.gif), install new pop rivets, yank old weather striping, replace and then follow directions backwards... If you dont want to pull the glass use some duct tape on the outside over the top and back to the inside to hold the glass up... unbolt glass, gears/motor, unhook wiring pull gears/motor out, drill & replace pop-rivets, reinstall..... /forums/images/graemlins/thumb.gif
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    For the longest time I thought my window motor was dead too (it was really slow before that), turned out a couple wires broke on the inside of the power window conector on the back side of the door panel. Replaced the ends with some I scabbed from the JYard and even my power doorlocks started working again /forums/images/graemlins/thinking.gif
    I needed to replace the rubbers so I done the motor too... now I just have to get around to doing the passengers side one of these days /forums/images/graemlins/thinking.gif (done the drivers side this past spring, maybe I will do the passengers side this spring /forums/images/graemlins/histerical.gif.... probly not unless it stops altogether /forums/images/graemlins/blush.gif)
  9. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Seems like a read somewhere that the regualtor is under tension so you have to be careful not to let it snap closed (and potentially cut you) when you remove the motor. /forums/images/graemlins/thinking.gif
  10. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    convert to a full top
    make tube doors
    move to Arizona
    problem solved
    sells doors for gas money /forums/images/graemlins/histerical.gif
    ps I have heard something about the tension being their too /forums/images/graemlins/confused.gif
  11. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
  12. unick
    Aug 16, 2003
    4,286
    when I took my motor out I pulled the regulator too. So I didnt have a problem with it cutting me
  13. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  14. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    Window Motor Replacement With Pictures /forums/images/graemlins/truck.gif
    Link doesn't work.. /forums/images/graemlins/1zhelp.gif
    can't get it to work eather. /forums/images/graemlins/dunno.gif
  15. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I havent done one on a k5, but if its like all the other gms, with the big clock spring in the middle of the X be VERY carefull, I have seen 2 guys hands get sicssored and almost lose fingers.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  17. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
