Assembling a 203 use gaskets?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Dec 27, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I am putting a 203 back together and I am wondering if It is ok to use blue RTV sealer on the adapter,
    input shaft housing,and the front output housing or if I should just get the gaskets does it matter???
    TIA
    *wink*
    my 79 rust bucket will run over your 2001 chevy 4X4 tahoe plastic wagon
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I used high temp black rtv on mine but it leaked. The gasket in there now doesn't leak at all so I'd go with the gasket.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://24.55.50.76:81/k5/> Pictures</a>
  3. WillThisNameWork
    WillThisNameWork Registered Member
    Dec 27, 2001
    7
    Phoenix Arizona
    I have not worked on a 203 (ever) but I can tell you that a gasket is the only way to go. RTV can work if you do not put to much (most people do) or of course, put to little, but it will never last as long as a prefab gasket.
    Also, if you go with the gasket be sure to use a little RTF with it. This will give you a little room to breath if you fail to tighten the bolts within an acceptable torque tollerance (this also means to tight). Again, do not use to much as this will cause leaks, just BARELY enough to coat the surface of the gasket.
    Good Luck....
    WillThisNameWork
