Assorted spring plates and u-bolts
Discussion in 'Suspension | Axle' started by ZZ4x4, Jan 11, 2006.
  1. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Update:
    I have only the following left:
    Spring Plates:
    14B spring plates ( cradle type which go BELOW the axle tube)
    12B spring plates (cradle type which go BELOW the axle tube)
    10B / D44 front spring plates
    U-bolts:
    Round 3 5/8 dia for GM 11.5 Axle 11" long
    Round 3 3/8 dia for 14B 7" long
    Round D60 -stock 7" long (plus longer wider one for diff housing)
    Square 2.5 width x 7" long
    Sorry, no matched sets of extended length u-bolts. Just stockers.
    Jeff
  2. TravisO
    TravisO 1/2 ton status
    Apr 17, 2003
    143
    Aloha, OR
    I could use some longer U-bolts for my front Dana 60. I've got stockers now but they are not long enough for installing zero rates.
    Travis
  3. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    PM sent.
  4. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    spring plates for a 60 and 14 bolt?
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    spring plates for a dana 60?
  6. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    PM sent
  7. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Smokey,You're next in line after JJ350:wink1: . Have just one set of the D60 / 14BFF plates left....
    Thanks,
    Jeff
  8. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    cool, just let me know.
  9. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    you got a passenger(diff) side spring plate for a dodge d60f?
  10. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Sorry, only GM stuff.
  11. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i need 2 6 degree shims steel ones
  12. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Sorry, no degree shims left.
  13. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I need a longer U-bolt for the diff on a 10b front. I have a 0-rate and a 6 leaf pack. I can get a measurment tomorrow.
  14. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    I need a set for a dana 44 front 9" length, one of them is longer though.
    jesse
    PM me please
  15. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Just updated the original post with what I have left.
    Thanks.
