astrooooooo?
Discussion in 'The Garage' started by binjabr7, Apr 19, 2004.
  1. binjabr7
    binjabr7 Registered Member
    Jan 3, 2002
    14
    hi
    any body can tel what car use the same rear diff 5 lug .astro van. 94.all w /d Ls
    so I can search in scrap yard
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm pretty certain none do. My friend had an 89 astro, and I know in that body style the rear axle is offset to one side, unlike any other GM vehicle of the time.
  3. dyeager535
    26,978
    Unless they changed the suspension from teh earlier ones, its also leaf sprung, of which no car that vintage was.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    so good luck,
    you need axle from same make model vehicle
    did they use 7.5" or 8.5" axle under the astros ?
  5. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Astro and S-10 and 82 - 92 Camaro's share many of the same suspension parts.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they used a 7.5"
    the s10 and camaro are the same diff, the axle shafts are different lenghts though.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] quite wrong. s10s have leaf springs under the axle. Astro is above the axle. Camaros were not leaf sprung.
  8. binjabr7
    Jan 3, 2002
    14
    thank you guys .
  9. BlackDog714
    Jun 8, 2002
    260
    Indiana
    This is true, however it doesnt mean that they still dont share many suspension parts.
  10. dyeager535
    26,978
    Front stuff yes. Rear, almost nothing, if anything. (shocks maybe?)
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have a 94 safari (same thing as astro) and a 89 s10, the safari uses a plastic leaf spring and the s10 uses a standard steel leaf. im not sure if/when they changed anything but i know what i have is different.
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    quite correct, older Astros had a single 3 or 3.5" wide plastic leaf spring
  13. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Unless they had the HD tow package, then they had the steel multi leafs just like the s-10.
