At home wart freeze-off
Discussion in 'The Lounge' started by TSGB, Mar 5, 2007.
  1. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Picked up a box of the Compound W stuff a while ago. Used it on two warts on my hand, and nothing happened. No pain, but a bit of soreness a day or two after. Then two weeks later, the skin turned white (after a shower, and another when doing dishes), and tore off. The wart was seriously diminished, but not quite gone. The package says repeat applications may be necessary.
    :waytogo:
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    never had a wart
  3. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Me either until about 10 months ago, then BAM, four of the little bastards.
  4. burban89'sgirl
    burban89'sgirl 1/2 ton status
    Feb 5, 2007
    618
    In da hous with da crazies
    you have more patient then me i cut that little bugger off my hand it drove me nuts:doah:
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have 2 that keep coming back. I have cut them off and they bleed like a mofo. The come back after awhile though. I have also had the doctor freeze them with liquid nitrogen and they went away longer but still came back.
    Harley
  6. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    Knew a guy in one of those branches of the military... you know hush hush stuff. I know cause he NEVER EVER talked about it. One time he was gone for a couple weeks, when he came back he had a bunch of warts on his hands. All he could/would say is that "the water was nasty". He went into the doc and they froze off something like 30 or 40 of the little things.
    I think that whereever he was, he was covered except for his hands and then whatever happened affected that part of his body. It was weird to see his hands with all these little warts on them. Then nasty when they were all white and dying, but then totally cool to watch them fall off.
    I am glad it didn't happen to me. :D
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    When the doctor froze mine they turned black after a few days and look gross. I proceeded to rip them off because they looked nasty.
    Harley
  8. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    What I did for the ones on my hand:
    Stuck the wired from a heavy gauge wire hanger in a blowtorch untill it was as hot as possible
    Burned a perfect little circle as far down as I could stand over them
    Wrapped them up with bacitracin
    Took care of it
  9. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    You've got more balls than me. I'd have to have people hold me down for that ****.
  10. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Doesn't hurt if you get it hot enough
    I'm trying to IM you on MSN BTW
  11. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    ...and don't you have ****ing metal shot through your wang? WTF?
  12. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    Whatever you do... dont pull it out with a pair of pliers. I had a planters wart on my foot that I yanked out, the roots were a good 3/4 of an inch and it bled for days.
  13. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Yeah, three bars. :D I'm at work. Trying to be sneaky. I'll be home by 11, my time.
  14. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I had about 30 or 40 on my toes when I was a kid, and my sister had them on her knees, maybe I was in bad man territory!
    But as for pulling the "seeds" out, I pulled one of those things out of one on my pinky and it bled for HOURS, and I mean gushing if I didn't hold it.
    I haven't had them in many years but I hate them now. My old girlfriend had a couple on her left hand and I couldn't hold that hand without getting the wheebegebies.
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have corderized (sp) both of mine after I cut them off to help stop the bleeding and to try and kill them a little deeper. I usually (I have done it several times) take a lighter and heat up a pointed metal object as hot as I can get it and smack it down on the bleeder and move it around. It is interesting listening to your own hissing sound. :crazy:
    Can you rip out all kinds of warts or only certain kinds. I might have to try ripping them out next time they get big enough.
    Harley
  16. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    well ive never had one, but does it not hurt like hell to rip a part of your flesh that runs 3/4" into your body off?? seems like there would be a lot of pain there. or are they not as 'attached' as everything else?? just wondering..
  17. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    They make this prescription stuff that is like poison oak that you can put on them. A dermotologist will give it to you. Only thing that would work for my GF. Gives you a crazy bubbling blister, but after a week or 2, its all gone.
  18. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    its called acid, nothing like a good chemical burn to rid your flesh of unwanted growths
  19. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    can always keep trimming them down with a razor blade... had one on my left hand, and i cut it back a couple times, then cut around it the last time, and not all the way to cut it out, it turned a dark brown like dried blood and i picked it out, no more since ... knocking on wood...
  20. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    When I was in junior high I had one on right middle finger at the first joint (palm side).
    I took a fingernail clipper and pulled the wart and its' root out leaving a hole!!
    It never came back.
