at what point do shims hurt?
Discussion in 'The Garage' started by muddybuddy, Oct 18, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there, i was running 8" of lift in the rear with 5* shims and bought 20* degree shim a while back to try to eliminate the vibs. the driveshaft was lengthened as well. however i never got around to putting the bigger shims on because i read on here that actually running with no shims causes the vibs to cancle out or something. i just added zero-rates and was wondering which would be the best way to get rid of as much viberation as possible, no shim, 5* shim, 20* shim?
    thanks.
  2. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    a 20 degree shim seems a bit much for an 8 inch lift...been awhile but i think mine were either 6 or 8 degree shims for my eight inch lift...
    what you are trying to accomplish is match the angle of the pinion with the angle of the output of the t-case. someone else will probably chime in with some more info.
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well i now have 9" with the zero-rates.
  4. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    That's sure alot of lift for only 35's. Put some 44's on that bad boy.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i know, 4os or 42s are comin when i get the funds :D
