ATF fluid gimick???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Mar 6, 2000.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Maybe I missed it but I havent heard the final verdict on this AFT fluid gimick. Has anyone else tried it, and was it really worth the time and effort?? Just curious.. Thanks
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    After reading many threads on this topic, I think what we need is a guinea pig. You try it and let the rest of us know how it worked.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  3. BlazerBoy
    639
    Chicago IL.
    I dont know how much I like that idea?? lets flip for it..
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Tell you what, this upcoming weekend I'll try it. I'll post the results right afterwards.........
    Pray for me!!!!!!!
  5. Bondo
    Bondo 1/2 ton status
    193
    Bath, NY
    Actually, I tried that with one of my classic cars. It didn't completely cure the problem, but I'd say there was a 90% improvement. I'd do it again any day!!
    BONDO WILL FIX ANYTHING!!!
  6. DangerB
    DangerB 1/2 ton status
    420
    Frisco, TX.
    Somebody please tell me what youre talking about. Is it putting ATF in your motor? To fix what?
    DangerBrett[​IMG]
    <font color=blue>life is a race, you have to look good and go fast!</font color=blue>
  7. Bondo
    193
    Bath, NY
    Yes. You mix ATF with water and pour it into your carburator. I don't know how it works but I had really good luck with it.
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have never done this but it was talked about last month.
    From what I read you take 4oz of ATF in a jar then unplug your pcv from the hose it's hooked to then with the motor running stick the open end of the hose in the jar so the vac will suck it straight down into the intake. When the ATF hits the pistons and valves it breaks up all the carbon build up and spits it out the tail pipes.
    Some who have doen this warn not to have your wifes car or any thing behind your rig when you do this....Black stuff everywere!!!
    Agin I have never done this but from what I read it does work for removing carbon build up on high millage motors.
    Burt4x4
    Rock ON!
  9. DangerB
    420
    Frisco, TX.
    Seems like all that carbon might tear your rings up.
    DangerBrett[​IMG]
  10. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    The whole idea is just too hokey for me. Would like to here from some more brave souls AKA guinea pigs. Last month someone mentioned a GM Top Engine Cleaner that worked well & I've used BG44K fuel treatment that smoothed my idle out real good.
    <font color=red>David, '86 K5</font color=red>
  11. Bondo
    193
    Bath, NY
    I was really skeptical on it at first, but I decided to try it on an old car that I had that smoked terribly. I decided I might as well try it because the next step was to rebuild the engine anyway. I dumped it in and HUGE clouds of smoke came out of the exhaust. But after a couple of minutes the smoke had cleared and the car was running great and hardly smoking at all. I tried it again and the car quit smoking almost completely. This was two years ago and I'm still driving the car without having rebuilt the engine yet. It went from smoking so bad that you could lay a smokescreen to hardly smoking at all. I thought it was a dumb idea at first but it was unbelievable what it did for that engine. Just my .02.
  12. turbo
    turbo 1/2 ton status
    Feb 18, 2000
    109
    It works and is harmless except for turbo engines the carbon is not good for the turbo.
    Also someone might call the fire department over the smoke.
    The new rage is seafoam.
    But another good ATF trick is rig an extra windshield washer with atf to squirt in carb on damand you would be amazed how fast the tail gaters back off when the smoke comes pouring out your tail pipe.
    Always good for a laugh.
  13. _DeeVee8_
    _DeeVee8_ 1/2 ton status
    149
    I thought of that once-- but was worried I 'd "become the trail" after that..
    Heh heh!
    The ATF thing is just cheaper than MArvel Mystery oil!
    Pour a can of it in your oil about 150 miles before and oil change-- cures thing like stuck lifters and sticky valves--it's just lube!
    -DV8
  14. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    A quick summary of the posts and personal experience:
    Works best with high milage engines, low mileage you may not notice anything.
    Don't use on turbo/superchargers.
    Don't use if have aluminum heads.
    Don't park with the tailpipes pointing at anything you don't want to clean.
    Fire department may be notified.
    Worked some on my 3,000 mile 350, enough I'll try it again in about 6 months
  15. DangerB
    420
    Frisco, TX.
    So are we talking about putting it in the carb or sucked up the pcv? If carb, how much? Ill try it on the DODGE.
    DangerBrett[​IMG]
  16. Waxer
    1,857
    Long Beach, CA.
    From all the posts, they all say to let it get sucked up by the pcv hose.
    3 more days til the weekend and I'm gonna try it.
  17. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    It's the "cold" ATF fluid that's the trick here hitting the hot carbon build up right?
    Is colder better? I.e. at room temperture give o.k. results, but a little colder (in freezer for 10 minutes maybe) would give better results?
    ...you first!...
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado (a.k.a. ThunderDog)
  18. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I used to work at a junk yard many years ago. To make cars run after setting for years the old boy would get it running and then have somebody keep it running while he "trickled" atf in the carb.I have never seen so much white smoke in my life....but the stuff really worked . It cleans off the carbon as well as unsticking rings. The colder the better.Do not put too much at once in at once and if the motor dies...you might as well get some new plugs .[​IMG]
    <font color=green>Eagle86K5
