ATF in 205 xfer
Discussion in 'The Garage' started by LVJimmy, Feb 25, 2006.
  1. LVJimmy
    LVJimmy 1/2 ton status
    Aug 22, 2005
    301
    Lost Wages, NV
    Does anyone run ATF in their 205. i know several people who do who do not seem to have any problems and wanted to know if anyone else did.
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    just run 80-90 weight gear oil and be done with it;)
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I would also like to know this regarding a 208. I have over 20 litres of the stuff to get rid off :eek1:
  4. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    ATF is NFG for gears far too light weight. Of course the gears are so tough they will still last for "x" number of miles/years.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Some 205's came factory using ATF.
  6. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    A 208 is supposed to be filled with Dextron III
  7. LVJimmy
    Aug 22, 2005
    301
    Lost Wages, NV
    It started with one guy who rebuilt his tranny and could not stop it from leaking ATF into the transfer case. He fianlly said the hell with it and changed the transfer case over to ATF. He ran it for 10 (112,000 miles) years without a problem before he sold it. Since that time I have run into several others who had the same problem and did the same thing. I don't have any updates on how well thier 205 's lasted
  8. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    My 1985 k-3500 owners manual calls for dexron ll. I've had it for 5 years, the previous owner hauled horses and a 28' fith wheel. It has 145,000 miles on it, I resealed the case last summer and it has very little, if any wear on the bearings and gears. The atf gets changed once a year. No problems.
  9. LVJimmy
    Aug 22, 2005
    301
    Lost Wages, NV
    Call me stupid but is that a 205 or 208?
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    if its a 3500 its a 205. and jpeater a 208 and 205 cnnot be compared in this thread they are completly differant. i knew atf was ok but last time this disscusoon came up i was called crazy:rolleyes:
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    the 85 one ton i got my 60 out of had ATF in it... it was a smooth transfer case when i drove it as well.
    Grant
  12. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I won't dispute, that just defies logic........... Why is it ok in a 100% gear driven transfercase. Then not in a rear diff, or planetary hubs, whats the difference?
  13. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i have no idea :dunno: but the factory reccomends it
  14. 85k30
    85k30 Registered Member
    Jan 1, 2003
    24
    i just removed a 205 from a 89 crewcab in a junk yard and it had atf in it.
  15. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    ....I might just swap the fluid in my junk and give it a go. Might help in the winter when its -35c.
  16. 85k30
    Jan 1, 2003
    24
    my 1986 chevy service manual says gear oil. my 1987 service manual says dextron II. so in 1987 they changed to dextron II.
  17. rumbly truck
    Jul 4, 2005
    132
    utah
    Remember, a transfer case has a straight through power flow. A modern differental has a hypoid cut gear set, in it you get a wipping action across the gear face. This is a different action for the oil to deal with, the oil has to transfer the power, and change its direction. Remeber it has been speced for oil viscosity and bearing clearances to match.
  18. bigkennye
    bigkennye Registered Member
    Nov 8, 2005
    45
    virginia
    I was told that the 205 uses 80/90 gear oil (probably because it is gear drive) and the 208 uses ATF. Thats what I was told.
  19. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I hear ya, thats makes perfect sense.
    Just like the gear train in any heavy diesel works just fine with 15-40 lube.......it's all coming together now
