atlas in a blazer
Discussion in 'The Garage' started by new2k5, Dec 24, 2002.
  1. new2k5
    new2k5 1/2 ton status
    Dec 16, 2002
    128
    south eastern PA
    i found out i have a bad fork in my t case wich wont aloow it to go inot 2 wheel since i dont feel i comfortable splitting my tcase i would have to pay someone wich is gonna be pretty expensive and if their in there they might as well rebiuld it since it has a 167K so i am thinkin why not just shell out the extra and get an atlas. i found a group buy to get one fairly cheap. what all will i need to do other than just bolt it to the trans. also should i go 4.3 to 1 or 3.8. i know with a v8 you dont need as much gearing as you would with a 6thanks in advance
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    For a while I was thinking of maybe getting an Atlas.Having 4.3-1 would rock but,I dont need super low all the time.I run around on the trail in 4 low (2.6-1) but when I come up to an obstacle I wish I had 4-1.With the Atlas you have 4 high and 4 super low,nothing in between.
    For the price of an Atlas or a KluneV you could buy and ORD doubler complete from ORD with both cases and have 4 high,2-1,and 4-1. /forums/images/graemlins/grin.gif
    just my .02 cents /forums/images/graemlins/grin.gif
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I think Blk87 runs one in his Blazer.... /forums/images/graemlins/thumb.gif
    Marv
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Isnt there a strength issue with the atlas as well? It was my understanding that the atlas would not hold up to a high horse, big tire situation. Maybe it wouldnt be an issue for you though.
  5. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I have one in mine and love it. I don't need the 2:1 low or the extra 130 lbs., so I went with the Atlas. If you buy one, you probably won't be happy with the 4.3, it is too hard to stop on a heavy truck, even with discs front and rear. Do not buy their aluminum adapter. It is not needed. Use the adapter that mates a 700R4 to a NP 208 t-case. They told me it was, and I had no way of knowing whether or not it was since I was one of the first ones to even purchase the 27 spline input shaft model. Definately get the 32 spline front and rear outputs shafts. There are no strength issues with an Atlas. I wheel the pee out of mine, and so do many of my friends with 42's and 44's, big blocks, etc. None of us have broke ours. Installing the Atlas is basically a bolt in affair. You will need new driveshafts of course, but that is about it. You can re-use the stock cross member because you are not changing adapters. It is very easy to install an Atlas. If you have any more questions, let me know.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    thanks for clearing that up. /forums/images/graemlins/thumb.gif
  7. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    and Lord knows if Brian can't break it then no one on the face of this planet can. Anybody that can break 2 35spline hubs in less than 1 mile /forums/images/graemlins/eek.gif and has an atlas that lives is insurance enough.
  8. new2k5
    Dec 16, 2002
    128
    south eastern PA
    cool thanks guys i am debateing going with the 3.8 since its cheaper and i am worried about being to low for normal offroad drivein.
  9. 76k5Blazer
    76k5Blazer 1/2 ton status
    Sep 25, 2002
    176
    tracy ca
    if you primarly run rock get the lower one if you jsut run forest trails and suck get the higher one
  10. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Mike
  11. new2k5
    Dec 16, 2002
    128
    south eastern PA
    i run it all thats my problem i go camping and hunting in some fairly remote spots and go rockcrawlin at paragon thats why i think the 3.8 will be a good compromise its still lower than the 2.6 stock ratio but not crazy low like the 4.3 /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
  12. new2k5
    Dec 16, 2002
    128
    south eastern PA
    well i made my decision i am going with the 3.0 highlander with the 32 spline uprade. if it were a couple years ago before i had a @#%&amp;* fiance. i would definitely have gone 4to1 but since i am almost a married man i only get to go to paragon once a month if i'm lucky. most of my wheelin is on forest trails so according to 76k5 i guess i suck /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/smirk.gif i should have it in a month or less so i'll let ya know how it went and how it works /forums/images/graemlins/k5.gif
  13. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I always keep an atlas in my glove box. /forums/images/graemlins/thumb.gif
  14. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'm a little biased obviously but running a t-case built as a replacement for a D300 in a jeep in your fullsize truck can cause you some problems. They don't spontaneously explode but they're not a 205.
    We'll see how Brian's (blk87K5) holds up when he figures out how to lock his hubs........
    I have run into problems with having just a deep gear, I've been in more than one rock situation that required the 2:1 gear to make the truck work right and was really glad I could shift up. And when things get wet a 2 or 3:1 gear is mandatory. Then when you're in really big stuff, a lot of times 4:1 isn't enough if you don't have a deep geared tranny and axles.
    I'd have to vote for a cheaper system that has more options and is stronger.
  15. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I never did get that hub thing figured out so I just went to drive flanges. Having more gear choices is definately cool, I have to admit. I am a little biased towards the rock crawling aspect, because I *hate* mud.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif I bet you do.
    When I break my Atlas, not something little but a real break, you can bury me in a dress. /forums/images/graemlins/pimp1.gif
