atron tapered block installed - quick pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Dec 10, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I installed 8 degree 1.5" offset A-tron blocks.
    8 degrees is a lot, but on my longbed pickup 465/205 with the echobit shackle flip, that was what was required.
    The install was as simple as it gets. The radiused edges go up (opposite of what the A-tron banner ad shows) and that's really it.
    Here it is installed:So-so pic of shim block installed
    Closer shot of block
    Of course, moving the axle back will necessitate modifying the spring anchor plate for the relocated center pin. I simply drilled a pilot hole 1.5" up from the center of the anchor plate, then progressively drilled it out to 3/4".
    Here's a pic of the anchor plate
    It corrected my angle and centered my rear wheels at the same time. What more could I ask for?
    As always, picture quality leaves something to be desired, but my digital camera was $55 on clearance, so take that into consideration.
    -- Mike
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Try and get a closer pic if you can.
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Of what?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    The actual taper block from atron in relation to the direction that its mounted....yeah i know, stupid question, but could ya?
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    That one is full sized, but kind of blurry.
    If you look on the right hand side of the pic, you can see how the top of the block has a radius at the edges.
    Does that help?
    -- Mike
  6. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Jeff, Here is a picture of the offset blocks.
    clicky
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Cool thanks, pm'ed ya also /forums/images/graemlins/grin.gif
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Nice work! The degree'd offset is smart solution.
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,078
    486
    Grand Rapids area
    Yup, 8 degrees is about right with a 4" shackle flip. Or leave the taper out and get a CV shaft! /forums/images/graemlins/thumb.gif
