Att. fender hackers
Discussion in 'The Garage' started by Z3PR, Dec 27, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Has anyone trimmed thier fenders with a Dremmel using a cut off wheel ??? I've got some rusty virgin sheet metal to deal with, so I'm thinking, just trim them to make room for the larger tires.
  2. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    No, but I use my dremel (grinder bit) to smooth out the rough edges caused by my sawzall. Works great for that!
  3. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    im prety sure that will wear down too fast. it would probally take a long time too. when i did mine i forgot to clean off the fillings and now my white blazer has brown spots on it.
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Last time I trimmed I used a jig saw or saber saw. I have access to a air one that works kinda like a turkey carver. Works pretty slick. really narrow blade so it makes easy turns and moves fast enough that you don't have to keep the guide against the metal. Just like taking a pocket knife and cutting.
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I used a cut off wheel on my craftmen rotory tool (same thing) to cut a 2.5" whole in a piece of thin metal and it took several wheels and 20 minutes. I couldn't imagin trying to trim the fenders with one (the metal is alot thicker). I used a sawzall and it still took half hour, then another 30 minutes with a flap wheel ont he grinder to smooth out the rough spots. Using a Dremmel sounds like a weekend project. How much are you trimming?
    I would look at one of the spiral bits for sheet metal and go from there. I didn't have much luck with the one I tried to cut the radio hole out with though. /forums/images/graemlins/thinking.gif
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Never trimmed fenders befor. Sounds like a sawzall might be the better choice, and then the Dremmel to smooth things out.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    it'll burn out. spring for the right tools.
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I want to get one of those air saws, you know like a sawzall powered by air, Looks like it will be better for lots of cutting, I believe thats what Zakk used on his rig if I remember right.
  9. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I used the air saw on my rig, just trim the blade down to stick out about a 1/4" and your ready to hack.
  10. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    man i love seeing pics of that truck its so sweet! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I can't wait to get to see it in person, then again I can't wait to see any bodies rig in one piece, getting used to just having a frame on jackstands.
  12. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I used a 4.5" grinder with a "Zip-cut" disc (1/16" thick). To smooth the sharpies out I used a flap wheel disc on the same grinder. The cuts turned out real smooth and it didn't tear up the edges at all.
    Rene
  13. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I used a larger version of a dremil in the form of a die grinder. I felt like i had more control, but i did use a hand full of blades and it tried to burn the paint so i ran the garden hose over it to keep the paint cool. but boy did i get wet.
  14. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I used the Dremel to clean up after my angle grinder. I went through almost a whole container of those little disks. Sawzall or body saw has gotta be the best way to go... (or air nibbler if you can afford one!)
  15. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Die grinder with a cut-off wheel is what I used, dremel might be good for cutting fenders on a Hotwheels blazer but definitely undersize and underpowered for real fullsize vehicle.
  16. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Yunit, were you the one that posted that pic (or a link to it) with a drawing showing the measurements detailing how you cut your fenders?
    If so I'd like see it again, if you don't mind....
  17. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    If you use a saw-all...
    PRACTICE first... /forums/images/graemlins/smile.gif
    It cuts so well...its easy to get out of control.. /forums/images/graemlins/eek.gif
  18. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  19. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    dude .....ALL HAIL THE ALMIGHTY SAWZALL.....
    Hacking fenders is easy..just get some masking tape to out line the cuts, and let it rip...Beware...Because if not careful it will get out of hand quickly, and look like chit..
    Take your time.....
    TWISTING DRIVESHAFTS SINCE '00
  20. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,959
    249
    Released from Pueblo, told I belong in Southpark
    Die grinder, air shears, or best of all PLASMA CUTTER.
    Just finshing mine. all that left is some grinder work. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
