Attaching KC Lights?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nau81blazer, Feb 2, 2005.
  1. nau81blazer
    nau81blazer 1/2 ton status
    Mar 6, 2004
    329
    Cincinnati, OH
    Hello all,
    Has anyone ever attached KC lights to the A-Pillars of your trucks. I see this set up alot on *eeps, but never on a Full size. Is sheet metal enough to hold it or would some sort of bracket need to be fabbed to hold it better? Let me know what you think. Thanks,
    --Adam
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I plan on bolting a pice of contorted angle steel to the fender and then bolting the light to that. Shouldn't be too hard. If you want to get fancy you can box it in and shine it up to be pretty.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    When mounted in that position, they create so much glare off of the hood that you can hardly see where you're going. :( They're much more effective mounted up in the bumper/grille area.
  4. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    I was thinking of having them along with some on the front. More for pointing towards the ground on either side. Thanks for the suggestion though.
    --Adam
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Far be it from me to tell you where to mount your lights, but I think the biggest reasons that you don't see lights mounted to the a pillar of old Chevys is that it's not practical. We're usually so wide and tall, they'd get knocked off easy. Plus, though it can be done, it's not the easiest route. Most of the Apillar area is covered by the door anyway. I would suggest either a light bar or mount them on the bumper or grille area. I attached an old picture of my truck, but I still have the 6" 100Watt lights where you see them now. The location was a breeze to wire, they are protected by the grill, and you don't get glare off the hood or anything.
  6. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    Good points on the placement. Thanks for the input!
    --Adam
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I run lights in the location you're talking about on my DD which sees light wheeling from time to time. As long as you don't knock off your mirrors you're not going to knock off the lights. They're mounted to a piece of contorted flat stock which I cut a slot for in the wiper cowl. Not hard to do, two bends with a torch and a little grinding. Do they glare at night....yes, but they're 100 watt long range daylighters so any visibility lost to glare is made up for in sheer intensity down the road.
