Attention Carb Gurus!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Corey 78K5, May 25, 2002.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    What is the best way to tell what you got on a Q-jet? I got four carbs and want to find out what they are for rebuild kits. I was told to look for a tag but none of them have them all there is to go off of is the numbers stamped in the carb's.
    Thanks.
  2. Corey 78K5
    13,055
    Humboldt County, CA
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a google search?
  4. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Quadrajets part numbers are stamped on what would be the drivers side, underneath the secondaries. The number should start with a 70, or a 170. You can decode the number here <a target="_blank" href=http://www.carbs.net/quadnumber.htm>http://www.carbs.net/quadnumber.htm</a>
  5. Corey 78K5
    13,055
    Humboldt County, CA
    Thanks Troy!!! /forums/images/icons/smile.gif
