attetion suspention experts...how to remove a seized pin in a perch???HELP PLEASE!!
Discussion in 'The Garage' started by twoslo4five0, Mar 5, 2007.
how to remove a seezed pin from a perch???
  1. vice grips and wiggle it out (kerts sugusttion)
    22.2%
  2. torch and a money wrench (chas suggestion)
    33.3%
  3. pb blaster and a BFH (mannys suggestion)
    44.4%
  1. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    alright before i get started ive talked to manny,kert form 2IY4x,and chas (aka gmc4cw)...i need to know what yall would do in this situation...i pulled my suspention apart today and the pin in the passanger side spring is stuck in the perch...i unbolted spring and removed it and tried to pull the pin out by its self but its seezed in the perch...ive heard many diffrent ways to solve tis problem but im gonna start a poll to see what you guys think...
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    pb blaster let it soak, then use a punch and bfh and knock it through
    edit: wait, its stuck in the perch or stuck in the springs?
  3. twoslo4five0
    Oct 5, 2006
    6,615
    71
    suck in the perch.....there will be no punching it through...
  4. twoslo4five0
    Oct 5, 2006
    6,615
    71
    bump new title mabye more people will look now...
  5. twoslo4five0
    Oct 5, 2006
    6,615
    71
    oh and thats supposed to be a monkey wrench but i cant edit the poll..
  6. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    I voted for my own recommendation! :D
    PB Blaster or Liquid Wrench the sucker! Wait a bit, then utilizing a vice grip try to move the bolt side to side. Persuade it with a BFH if need be. If a no-go, then air chisel it off, drill it out. You have the depth since you have a sister 44 hangin' around, so by and by the drill bit will collapse the bolt in on itself and the sucker will come out. Just remember to use WD40/PB/LW or motor oil to lube it, so it stays cool.
    Best wishes. Exercise patience and remain stead fast in resolve. It'll come out. Oh, and don't cuss at it. Sweet talk it! :bow:
    Manny
  7. twoslo4five0
    Oct 5, 2006
    6,615
    71
    thanks manny you seem to always have a positve way to put a spin on things...is far as cusing at it goes that seems to work best for me....
  8. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    How about a compromise?
    I would pb the snot out of it, let it soak a while then heat it good with the propane torch. Grab the nut with your vice grips and yank...:weld:
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Sig line anyone???
  10. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    I suppose I did leave myself open for that:crazy:
  11. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Did you try smacking the perch with a BFH? Dont pussy foot around with it. If you have the cast perches you can hit them way hard and not hurt them. The shock of the vibes through the perch should knock it loose.
    Oh and shoot it with PB Blaster before you start.
    Ira
  12. twoslo4five0
    Oct 5, 2006
    6,615
    71
    yeah i did and actually bent the pin over ....i bought ta torch today so thats what im gonna try next...
  13. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Heat it up. Buddy and I just did this the other day to get one out.
  14. twoslo4five0
    Oct 5, 2006
    6,615
    71
    im glad to see that someone elce has had the same problem and im not just crazy...
  15. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    well? What was the outcome? I hope for the best! C'mon...there is a story here somewhere,
    Oh, btw....
    Manny
  16. twoslo4five0
    Oct 5, 2006
    6,615
    71
    i didnt even work on it tonight...to cold outside....insted i stayed inside and watched borat on dvd!!!pics will come in the next day or 2...
  17. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
  18. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    When all else fails, oxy it , it will come out, give it time, and try to keep a good attitude, when i get mad something bad usally comes from it. Good luck
  19. twoslo4five0
    Oct 5, 2006
    6,615
    71
    alright guys...i didnt get any pics but i heated the pin up tonight and tried the pipe wrench it just twisted the pin...the i took mannys idea and use a bfh...well the pin broke off...now it looks like i gotta drill it out...this axle isnt going back in the truck but i do gotta get this pin out before i sell the axle...this sucks...
  20. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    So sorry to hear that. The heating prolly weakend the pin and increased the stress shear. Like I said to you before, mark your drill bit and start drilling as close to the diameter as possible. Use WD40 or motor oil to lube. When you get down far enough, the pin will collapse on itself and should extract around the drill bit. Just use patience and it'll be out in 10 minutes or less. Wish I was there to help ya!
    Manny
