ATTN:1 ton guys,1 ton swap.brake question.
Discussion in 'The Garage' started by efilnikufecin, Jul 13, 2004.
  1. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i'm putting D60/14bolt with rear disc in my 91k5.did you guys change out the master cylinder or booster,or is it sufficient to feed the larger 1 ton brakes?i have 3/4 ton now with drums in the back and it's fine.just wondering what you guys are running?i ran the 1ton axles in my 78 and the brakes were a little mushy,but it was offroad only.the 91 will be drivin on the street and trail.thanks for any help.
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    before i swapped in my 1 ton axles, i changed out my vaccum power booster from my stock 1/2 ton k5 booster, to a 3/4 ton truck booster.
    It is bigger in diameter and length. This made a HUGE difference in braking for my k5.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    When i went 1 ton with my rig i did not change master or booster and it stops on a dime with a firm pedal.
