ATTN: AK-57 owners....
Discussion in 'The Garage' started by Roshambo, Feb 20, 2004.
  1. Roshambo
    Roshambo Registered Member
    May 1, 2003
    50
    South Coast, OR
    I'm starting a new job at a place that does marine fabrication, and it looks like I'll be able to spend some money on the Jimmy sooner than I thought I would.
    Keep in mind I am still sort of a noob when it comes to wheeling, all my wrench time has been on muscle cars.
    Anyways, I think for what I want my truck to do the AK57 is the smartest route, at least till I get crazy. /forums/images/graemlins/smile.gif
    So, my questions are: What shocks are you guys running, and how long did the install take? Also, I have a 4" lift already, so is that going to present any problems?
    It doesnt really look like too much of an involved process and I am ASE certified with a pretty big tool box. /forums/images/graemlins/wink.gif
    Any other tips/hints/ideas are welcome.
    -Joe
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Took me and a few friends about 6 hours to knock it out with lots of breaks. Of course we really didn't know what we had to do. You have to drill out your spring plates with a hole saw b/c the center pins on the springs are offset. You have to take your bumper brackets off and drill 1 hole into the frame. And other than that its 100% bolt on.
    Mine sits level with 6" front springs but I think you can get a 4" kit or it just depends how high you mount the bumpstops for the shackles (?) maybe 45acp can answer this part better.
    I'm running SX8000 shocks from TuffCountry. You may need to get extended brake lines or do what I did. get a peice of scrap metal about 5"x 1/2" drill two holes in it to move it up (where the brakelines bolt to the diff cover)
    Here are some flex pics... these were taken early into the ramping, so this isnt full flex (obviously since the tire hasnt lifted)
    http://www.texasoffroad.net/galleries/lonestar/album308/rti1
    http://www.texasoffroad.net/galleries/lonestar/album308/rti2
    I highly recomend, i had a few "man look at that crazy suspension" when I was at Katemcy Rocks 2 weeks ago.
  3. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Joe, There are lots of ways to do this but a easy fix with lots of travel and not to expensive. Use the Ford shock towers (E5TZ-18183-A) around $10-$15 each and angle them forward bolted to the frame. Use Rancho shocks (RS99036) around $70 each with 15" of travel. Make your own mounts and you will have close to 30" of wheel travel with the AK57. Not to bad to get 30" of wheel travel on the rear axle for under $800 - $900 total. 45ACP
  4. Roshambo
    May 1, 2003
    50
    South Coast, OR
    Sweet, nice pics! Now that is encouraging. /forums/images/graemlins/waytogo.gif
    How would you say the ride is with your setup? Ive been tossing around the idea of doing a 6" lift and at least going up to 35s anyways... damn, I havent even started and Im getting crazy. /forums/images/graemlins/laugh.gif
    Anymore pics would be great too.
    -Joe
  5. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Joe, The 57" springs are very soft (flex) so the ride is greatly improved. I am building a set (7") for Cory Rapoza/bikinnotdykin right now but thats the limit in how high I will go with it.
  6. Roshambo
    May 1, 2003
    50
    South Coast, OR
    Cool.. either I'm getting old or.. hmm, nevermind. But my truck rides very stiff with the RS5000's... much stiffer than anything Ive ever driven, even my old lowered 82 Z28. /forums/images/graemlins/dunno.gif
    I can't wait to get this thing started. What shocks to you run 45acp?
    -Joe
  7. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Joe, Rancho 99036
  8. Roshambo
    May 1, 2003
    50
    South Coast, OR
    Joe, Rancho 99036
    Note to self, read twice, then ask. /forums/images/graemlins/blush.gif
    Whoa, I'm not a stranger anymore. /forums/images/graemlins/laugh.gif
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I am running Rancho 5112s.I built a bolt in upper mont and welded the lower mounts to the axle.I have changed my setup a little since this pic was taken but you will get the idea.The install only took me 2-3 hours.The only thing I can realy think of to recommend is install some bump stops.It is very easy to over compress these springs and ruin them.
    Flex= /forums/images/graemlins/yikes.gif
  10. Roshambo
    May 1, 2003
    50
    South Coast, OR
    Thanks for the pics and info Frizzlfry, I'll have to add bumpstops to the list then. /forums/images/graemlins/wink.gif
    -Joe
  11. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Sorry to hijack but will I have to lenghten my driveshaft for the 6" lift? I think I heard that you shouldnt with the ak57
    Nick
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    brian didnt have to on his burban(running springer, and to this day the only one i know of, but same stuff in the end) marv told me that he has had a person or two with lenghtened drive shafts that had to shorten them back down to stockish length with the springer once the blocks are gone. the axle swings FWD as it comes down a lot more than with the stock setup.
    grant
  13. unick
    Aug 16, 2003
    4,286
    ok but Ill still need to do the front right?
  14. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yes, but if you like a spacer on the front should be fine.
    brian also is running the stock front shaft with 6 inch springs and ORD shackles. they are stif enough so as not to flex on normal driving but if he were to flex it out then he would pull it appart.
    grant
  15. Roshambo
    May 1, 2003
    50
    South Coast, OR
    So, I may, or may not have to lengthen the DS if I go with a 6" lift? /forums/images/graemlins/thinking.gif
    -Joe
  16. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    some have to some dont. i think it depends on the t-case and tranny being used along with what front axle, as they all add or subtract an inch or two here or there.
    nick, i would go with a new front driveshaft once you get your D60 in. IF you are going to go with the double then i would wait for that or get your front shaft lengthened.
    Grant
  17. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    What Grant said. Mine are stock lenght. My rear springs are built a little bit higher than six inchs (to account for more weight of a suburban). I put the burban on a frame lift and let the axle drop until the bracket hit the hanger and there were no problems with the driveshaft (or trackbar for that matter.) The front I have to investigate, but not really worring about it until doubler and tranny swap is done.
    And yes I have the only Suburban with "orignal" springer suspension. /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
  18. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    If I get the ak57 kit what size rear 57" springs would I need to match my 6" of lift in the front? 2" or 4" or what? /forums/images/graemlins/dunno.gif
  19. bikinnotdykin
    bikinnotdykin Registered Member
    Apr 5, 2003
    24
    utah
    I had the ak57 kit and twisted the springs bad on my 2nd trip out in moab on easter weekend, I luckily found a local who had a set of 1 ton 56" springs he sold me for 20 bucks. I have been running these with no problem but the ak setup takes some getting used to. I sometimes wish I wouldn't have spent the money on it. It is also unpredictable at times. I was also doing some hard wheeling in moab too. and I did not have a track bar on at the time I bent the springs. in my opinion the ford springs are way too soft to do anything in the real world other than break and ramp champ. that's my review take it how you want!!!! /forums/images/graemlins/doah.gif
  20. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    [/ QUOTE ]little off topic but when you flex dont those shocks compress enough were it breaks the mount on the body or frame
