ATTN: anyone running 38" and up tires, balancing ideas
Discussion in 'The Garage' started by Okiemuddog, Mar 9, 2004.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    ATTN: anyone running 38\" and up tires, balancing ideas
    Okay guys, I am upgrading from my worn out 36" hummer tires and going to 38x14.5/15 TSL/SX's. I have heard these can be a monster to balance. I have heard of using golf balls in the tire, balancing sand, and even steel shot for reloading shotgun shells. I am just wondering what technique you are using to balance your tire, I am running these on DD, so I have to have them balanced. I am open to any ideas or suggestions, just figured I would ask before I tried to have the monsters spin balanced.
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: ATTN: anyone running 38\" and up tires, balancing ideas
    Gladyou posted this, I'm getting my 38's next week /forums/images/graemlins/waytogo.gif
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    wish I could help, My 38.5x 14.5 TSL SX's are on beadlocks and aren't balanced.
    I have heard the equal stuff works pretty well.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nobody would balance mine except a semi truck shop, so I didn't balance them, and I have no complaints, they roll fine down the road IMO.
    16/38.5-15 TSLs here
  5. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Mine were mounted and balanced before shipped to me by 4wpw. they also put the equal stuff in also and I have no signs of vibes from the tires (38's). Guess it works /forums/images/graemlins/thinking.gif
  6. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Got 10 mph out of 6 golf balls in each tire. /forums/images/graemlins/woot.gif Now I can do 75. /forums/images/graemlins/whistling.gif
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Made a big diff on the 42's on Or2plays burban.
    Grant
  8. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I have a box of 50 golf balls I bought for $20 I'm going to try in my 38's
    I swear my tire guy said one of my tires if off by 62oz
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The powder bags worked fine for my buddy and I.
  10. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    My uncle owns a Tire shop and we put my 38.5's (Bias Ply) on thier best balancing equpiment and those tires will damn near bounce you out the seat at 75mph!!!! /forums/images/graemlins/yikes.gif
    What is this "equal" stuff? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  11. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Equal is a polymer powder that you put in the tire before mounting it on the rim. The stuff comes in little bags and you just throw the whole bag in and as you drive the bad disintegrates. As the wheel rotates the equal automatically disperses itself to the out of balance spots in the tire using the centrifugal force.
  12. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Yup thats the stuff! it works great, I run it in my 38's! /forums/images/graemlins/peace.gif
    Bill
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    My 39.5's are unbalanced, no golf balls, equal, or anything else. They have one spot where they are a little annoying (~52 mph) but anything faster or slower and it's all good. It'll cruise at 65 nice and smooth...
    I'd mount the tires up and take it for a drive before you do anything as far as balancing. I think the lead weights amplify problems rather than help out when you get to the larger sizes. I have no proof of that, but it sure seems that way.../forums/images/graemlins/smile.gif
    Rene
  14. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    There is alot out here if you search on CK5 or Pirate. The subject has been beat to death. If you wheel anyware ware you might loose a bead when its wet, don't use equil or any of those balancing powders/sands. They clump up and stick to the sidewall. We even had problems with it with condensation and oil/blow-by in a on board air system.
    I have herd steel shot or BB's work very well.
    Persionaly I use Golf balls in my 44's and they work great. I had one tire that was over 2 lbs off and it required 14 balls to get it ballanced. Had another tire that only needed 3 balls. So find yourself a bubble balander and figure out exactly how many you will need for each tire, no sence putting more in there than you need to.
    I have also had trouble with the tires that have alot of weight in them when used in the front. When going around a corner all the stuff in them likes to slosh to one side and cause death-wobble.
  15. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    groove the tread blocks.
    that's all I did and the ride is vastly improved.
  16. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I only balanced my 38x12.50's on the front. It took A LOT of weight per tire, but it was worth it IMO. I couldn't do more than 45 mph before it felt like my whole front end was gonna fall off! /forums/images/graemlins/yikes.gif I wish I would have done the rears too. They vibe pretty bad anything over 60 mph. But they are now "trail only" tires, so I don't think I'll be doing anything with them.
  17. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i never could get my 36s smooth...till i took the weights off of all of them....turns out when wheelin aired down they weights will move around causing them to shake worse....ive had the best luck with nothing at all....
  18. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    ...I'd mount the tires up and take it for a drive before you do anything as far as balancing. I think the lead weights amplify problems rather than help out when you get to the larger sizes. I have no proof of that, but it sure seems that way...:)
    Rene
    I was actually thinking along those same lines. Given that a spin-balancer pin points the spot for a small amount of weight to be centered, usually between 0 & 1.5oz. Some of my wheels have 10+oz, which spread about 25% of the way around the wheel; way forward and aft of the area pin pointed by the balancer.
    So, in that light your theory makes sense. I'm gonna try ripping the weights off add see how she does..... /forums/images/graemlins/waytogo.gif
  19. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    That is the same thing I run in my 38x15/16.5 TSL radials /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif damn I run smooother theeaan a SUPER TUNER!!!!!! /forums/images/graemlins/peace.gif /forums/images/graemlins/yikes.gif
  20. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I had my tires balanced and they put on the sticky weights on the inside of the rim. Only problem was the weights don't clear the calipers. On tire had 18oz of weight on it. Could I break the bead and stick the weights on the inside of the rim??? Or would they come off and trash the inside of the tire. I thought about using equal but the amount I need would be like $90.00 The only option I see is BB's. BTW I paided 4wheelparts to mount and balance my tires but they showed up in boxes instead of mounted and balanced /forums/images/graemlins/angryfire.gif
