attn: anyone who's gone TBI to carb on your trucks!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 01maroonz71, Jan 13, 2007.
  1. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    hey guys, well...the motor is is..the manifold is on, gonna throw the headers and carb on tomm....now my question is...
    should i just use the stock wiring harness and only hook up the few necessary wires and leave the rest to dangle??? or should i get a harness from the wrecking yard out of an older non-TBI truck???? what did ya'll do??
    also, i need to drop the dizzy in tomm. and im wondering the best way to do it...when i bough the motor the dist. was not there, so i can find TDC then install dizzy pointed at cylinder 1 right??? then some vaccuum lines, and a fuel line and i should be good to go i belive!!!!
    well, thanks in advance ya'll
    ~Dave
  2. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    nobody's done this???
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah. Its so easy a cave man could do it.
    Need a HEI dist or dizzy? TBI dist wont work.
    Dont use the stock in tank pump without a regulator with a return line. Too much pressure for a carb
    Need to figgure out a way so your torque convertor will lock up..
    I am sure there is a bunch of other stuff you have to do to go back to the stone age.
    But i have never done this I stayed at a Holiday Inn last night.
  4. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    I can't think of a single good reason to do this. Especially if you are doing it to an 01. Carbs are less efficient, don't start as well, don't like to run at much of angle, (like what you'd find when off-road). Not to mention that pretty much any mechanic these days can diagnose & repair whatever ails your TBI.
    Do what you want, but I need more convincing. :confused:
    BTW, I'm switching TO TBI from my carb.
    Later,
    Buddy
  5. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    01...no sir, it's an 87...the 01 in my names is(was) my daily driver...the truck/motor in question is my offroad toy
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Still doesnt answer the Question as to why you would want a carb over tbi:confused:
  7. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    my original TBI harness that came in the truck is chewed to hell, burnt, and cut all up...basically trashed b/c the guy who had it put in a a carbed motor. i want a carb so if im out in teh woods and something goes wrong i can fix it right there on the spot...TBI has left me stranded before....down here in FL there are no rocks or anything, just mud...so the fact that the carb can't run off camber is not a big deal.
  8. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    I love those commercials.... :haha:
