ATTN BBC AND AutoTrans Folks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, May 21, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I have a TH350 trans, a NP205, and a 454...
    My Problem you ask? I have a torque converter that (after I installed the trans and transfer case) I found will not bolt up to the engine's flywheel. It measures 10" from one bolt hole to the next.
    I have another TQ that measures 11" bolt-hole to bolt-hole, just like the 454's flywheel. This TQ is from a TH400 with an Oldsmobile bell-housing. My understanding is that TH350 and TH400s use the same type of TQ? I want to make sure that this thing will work before I tear everything down just to put the TQ in and find out it won't work. But, if they are the same, why the different bolt pattern???
    All I have left to make my truck streetable (after 3 months solid work...)
    * Trans lines
    * Front and Rear driveshafts (suggestions???)
    * Ignition system (Mallory Unilite distributor needs install)
    * Belts
    I hope that June 8th the funds will come to finish the project. Then I still need rims and tires. Driveshaft FYI...
    rear diff= 14BFF
    front diff= 8-lug 10 bolt
    Thanks again guys! Steve, this place is the BEST! Thanks for answering questions that no place around here can touch!
    <font color=red> Check out my truck @ </font color=red>
    <A target="_blank" HREF=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</A> [​IMG]
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The 400 converter will fit right into a TH350, I ran one like that for years. Also, alot of 454 flexplates have a dual bolt pattern, to where it will accept either the 11" version converter or the 10". Rotate your flywheel to the next set of bolt holes and see if that 10"er won't bolt up. My 454 flexplate has the dual pattern.
    ken
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    GM used 2 different bolt spreads for the converters. If your flexpate is not set up for both patterns you will either have to get a new flexplate or a new coverter. If you are going to replace the flexplate, I would Highly recommend getting A thicker race type flexplate. The stock flexplates are thin and will crack under the strain of a mild bigblock. A good T.C.I. or other flexplates are available for 60-70 bucks. Change it once and never agian! I cracked one in a truck before. Ain't no fun to change!
    your right. I don't understand the jeep thing!
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    You bring up a great point about shredding a flywheel... my last P/U with an EFI 350 and a stage II shift kit ripped the old one off the crank right after the bolts! What made me think I could use a stock plate on this 454? And its not mild, we can leave it at that... Compition Cam .524 lift, Edelbrock Air-Gap intake, headers, Holley 750CFM, etc etc etc...
  5. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I just completed my new 454. 9.25 comp. comp cams hydraulic roller, roller rockers. Holley projection. and your damb sure I used a New T.C.I. flexplate!!
  6. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Very nice setup! Did you have the engine dyno'ed? That must be a motor with alot of kick!!! Did you base it on a rectangle, oval, or peanut block? Mine is a oval... but I did not use any roller parts... YET! So far, I have spent $3500 rolling chassis and drivetrain (the drivetrain came seperated from the truck...) and about another $2200 in parts to make this damn thing go (AND IT STILL HASN"T RUN YET)... and now I need new driveshafts; another $450+ And then there is still the small matter of getting bigger tires put on there...
  7. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    here is a pic of the shortblock. I am going to try and run the peanut port heads. I am going for as much "reliable" torque as possable under 5,000 rpm. If the heads don't work, I plan on useing a set of GM signiture aluminum oval ports.
    no dyno testing but I expect 900hp! lol. I am looking for 450-500 hp. and 600-625 ft torque by 3,800rpm. This is less than Comp cams told me I should get. I just hope it's enough!! I also have MSD box and a ton of other stuff. I figure I have almost 4,000 into engine alone. I am not afraid to throw some nitrous into it. If needed.
  8. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    If he swaps in a new flexplate doesn't it need to be balanced with the crank and dampener since the big block is externally balanced?
  9. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Here's a shot of mine in the truck...
    Isn't that just beautiful? I should keep a copy of that pic under my pillow!
    Here is what I need BaBlazer... if you can help drop me another message or an email...
    Like I said, I need the front (stock driveshaft) and a rear driveshaft adapted for the 14BFF axle. I need wheels and tires (35-38") on 16.5" or 16" rims... what else... I'll add more later...
  10. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    looks awesome! I think you should always keep a photo under your pillow. sweet dreams!
  11. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    If you buy a flexplate for a 454, it already comes to "detroit" specs with the new counterweight attached. If your engine has been rebalanced, it should be balanced to the new specs.
  12. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The peanut ports work great. I switched out a set of oval ports to peanut ports on my 454 and noticed a nice improvement in torque down low, faster off the line, etc. Do a bit of mild porting work (clean up the slag, etc.) and they will come alive.
    ken
