Attn. Engine Building Question
Discussion in 'The Garage' started by ABO, Apr 23, 2002.
  1. ABO
    ABO Registered Member
    Jan 16, 2001
    77
    The Burgh
    So I got the Crank and Connecting Rods redone for the engine I'm building and I'm measuring the Rod to Rod clearence on the crank, which is with in factory specs, but for high performance they recommend a greater gap. Now everything was balanced and I want to shave off .001 from the sides of each Rod. Will this drastically throw off the Balance?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    It will not throw off the balance, but I also do not see a need to do it anyway if you have the factory clearance already.
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I too don't see the need for this. The only real treatments I've seen done to rods are resizing them or shot peening them. I just went ARP crazy and got resized rods and left everything bone stock though. New bearings, pistons, and all that crap though.
  4. ABO
    Jan 16, 2001
    77
    The Burgh
    Thanks for all the info, I decided to go ahead and give them some more room hopefully It should be ok.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Keep this in mind, every place that there is extra clearance you lose more oil pressure. Loose fitting main bearings, rod bearings, cam bearings, rod side clearance, oil pump gears it all adds up to low oil pressure. Make sure you keep all the extra clearances to a minimum.
