Attn: Hack Masters
Discussion in 'The Garage' started by Polaris, Jul 22, 2004.
  1. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    I'm in a bit of a dilemma and could use some advice. I'm running a 4" lift and 36" IROKs. I have trimmed my fenders back to the inner fender and in the front I'm still having rubbing issues. I have removed my swaybar, so it articulates quite well and thus, it's easy to stuff a tire. In particular, I wonder what I could use to cover these sharp edges to avoid wrecking my new tires on the trail this weekend? The Bushwackers did not hold up very well (Bushwacker, not tree & rock whackers I guess /forums/images/graemlins/blush.gif)
    I'm not opposed to more /forums/images/graemlins/hack.gif, but what of the inner fender??
    Thanks for any tips!
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    A temporary solution and cheap to boot would be some trim lock. Just a rubber edge gaurd that slips over the rough edge and has metal peices inside it to help hold the shape. Probably get ripped off eventually also but it would get you going for the weekend. Door edge trim works good in a pinch too.
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I cut my inner fender up right about 6", then pounded it back with the BFH. That gave me more room to trim back the fender and not rub. Also, on mine, I notched the lip just a little then beat it back too. Not exactly pretty, but no sharp edges either.
    KP
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    ORD and others offer kits to move your axle forward or back to help aleviate this problem. Another solution is to move the front mounts foward and use a slightly longer shackle or move the shackle holders in the frame (more work than just adding an offset zero rate though).
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I cut my inner fender well too. As soon as my camera is charged I will take a pic for you.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I second the beating your inner fender back some and doing some more cutting.
    You could also move your axle forward some by redrilling the spring perches.
  7. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    what i usually do is remove the lower inner fender well bolts and move it foward so i can get in the back side. hack out the inner portion of the fender, then bolt back up and beat back the inner fenderwell with the BFH.
    you can cut enough and still have the inners.
  8. Kyle89K5
    2,273
    OKLAHOMA
    Here's an early pic of mine. It's been *refined* a bit since then /forums/images/graemlins/wink.gif
  9. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
  10. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I like this method, it seems like it should have a clean look to it.
    What's up with that shackle angle? /forums/images/graemlins/thinking.gif
  11. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif whats rubbing?
  13. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    You need to actually wheel it to have trouble with rubbing tires... /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/doah.gif
    Rene
  14. BOWTIE
    Dec 28, 2000
    2,018
    looks like the standard angle to me. /forums/images/graemlins/thinking.gif
  15. ugly_blazer
    Apr 12, 2004
    1,214
    It looks like the angle on mine also, but it is less than ideal. I will change mine soon to look like Tim's.
  16. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    [quote
    You need to actually wheel it to have trouble with rubbing tires... /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/doah.gif Rene
    /forums/images/graemlins/ignore.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  17. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    One word "/forums/images/graemlins/hack.gif"
  18. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Rene
    shhhh its damn near done... It will be ready to flex anyway... wheeling who knows, its too nice to wheel I think...
  20. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You could also toss a 1-2" body lift on there. /forums/images/graemlins/pimp1.gif
