Attn: K30 Owners ? About Hydroboost
Discussion in 'The Garage' started by IronMan, May 16, 2003.
  1. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    Does your hydroboost system leak? And is so how did you fix it? Mine leaked bad. Mostly from hose that came out of the reservoir by radiator. I planning on putting a whole new system in, but with a 2wd box for the crossover steering. I talked to a guy that said the fittings on the box are different from the 4wd one. This true? TIA
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Mine leaks only when I overfill the reservoir with the fluid. The steering box is no different from a K30 compared to a K10 except for the piston size, from what I've heard.
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I think the fittings are only different between older and newer.
  4. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    You are correct. The fittings are the same across the board, except for the vintage. Up to '79-ish, the boxes and pumps used inverted flare fittings and after 79-80-ish they went to the o-ring fittings. The inverted flare fittings are standard thread and the o-ring fittings are metric.
  5. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    My crew cab has a virgin system on it and (knock on wood) it has no leaks.
