Attn: Kert DIY4x...or opinions wanted
Discussion in 'The Garage' started by bnate, Jun 16, 2006.
  1. bnate
    bnate 1/2 ton status
    Mar 6, 2004
    138
    San Jose, CA
    Just a sanity check here....shackle flip bracket bolts to frame, but there is a space at the bottom of the bracket. If it was sitting flush, the bracket is taking the weight...as it is now, the bolts are taking "shear" weight, right?!!?!
    Is this common? Anything to worry about? Add a spacer under the frame?
    BTW, Kert does awesome work. Have ordered from him a few times.
    I think it's just my frame. PO decided to torch off the rear bumper, which may have effected something here?
    Thanks in advance.
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I would not worry about it. It looks like 85 to 90% of the bracket is flush to the frame, which is plenty. It may be that your frame is not square, instead of the bracket.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    just to double check, loosen the bolts on the frame, and tighten the two bottom ones first (leave all the other bolts in, just loosen them) This will ensure its tight to the bottom of the frame.
  4. AlphaMale
    AlphaMale Registered Member
    Sep 6, 2005
    63
    Las Vegas
    wouldn't the weight of the veh push down on the bracket making it solid rather than pulling it apart? Even when it flexes the tension of the spring takes most of the weight....could be wrong.
    But I agree with 79k20350 about tightening the bottom bolts first.
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Seems everybody beat me too it. Yep, I'd tighten the bolts on the bottom first and then smoke down the side bolts. Not uncommon to see frame rails that have had better days.
  6. bnate
    Mar 6, 2004
    138
    San Jose, CA
    Thanks everyone. Appreciate the feedback.
    Bracket is 100% square. Frame is 22 years old.
    Kert, you've always answered.... Thanks a million.
