Attn: KRAZIE87K5
Discussion in 'The Garage' started by thatK30guy, Jul 4, 2002.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dan, is this picture before or after you removed the 3" body lift for the 1" ORD body lift?
    Before or after?
    I'm trying to decide whether I want to run an 1" or 3" body lift to clear the 38" Swampers I have in mind. /forums/images/icons/wink.gif
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Wes-
    Look in at the front bumper on the driver's side... you'll notice the silver spacer... which is ORD's 1" lift. I personally don't like the 3" kits because it allows the body to have too much leverage on the mounts/bolts.
    Just my .02! /forums/images/icons/wink.gif
    -Dan
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Oops! /forums/images/icons/blush.gif /forums/images/icons/grin.gif
    Figured it would be faster to get a reply from you instead! /forums/images/icons/wink.gif
    So the total amount of lift is 7", correct?
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Correct. And I've got 36's with the fenders MILDLY trimmed, and I get close to rubbing on the trails!
    -Dan
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    After viewing the pics again, I think I'm gonna go with 6" springs, 1" zero rates on front and rear, and 1" ORD body lift for a total 8" lift.
    Should fit 38" Radial Swampers just fine, but if necessary, I will trim the corners of the fenders where needed. /forums/images/icons/wink.gif
