Attn: Krylon Painters
Discussion in 'The Body Shop' started by XHitman396, Jul 20, 2004.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so im broke, and the Blazer has seen some better days as far as paint, and anything else, goes. there is quite a bit of surface rust on the top of the cab, and some here and there
    i was told to use a small palm sander and 80grit paper to get the rust off and down to the steel, is that a little too course paper? this is only temporary, maybe a year or two until i can afford a real paint job, so looks aren't that important, i just want the rust gone
    a friend said he has some metel prep you wipe on the metal before painting (not primer), so after that, if i just shoot some gray krylon on there will it hold up to the elements of 4-wheeling while keeping moisture from getting to the metal and rusting again? will this work and are there any steps im skipping? thanks guys...
  2. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i would start out with 80, then feather it out some more with 180, then feather it out a little more with 220.
    prime it and paint it.
    it wont look to bad when your done.
    always helps to let the spray cans sit in a bucket of faucet hot water, the paint comes out and lays better.
    you can always get one of those nozzles that attaches to the can and sorta acts like a spray gun then.
  3. XHitman396
    May 3, 2002
    620
    im assuming that much sanding would not greatly effect the thickness of the metal???
  4. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    Use Rustoleum.
    /forums/images/graemlins/pimp1.gif
    Fred
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I used kylon rust tough paint till they quit making the color I used. Now I use the generic Walmart rust control paint cause its $2 instead of $4 a can
  6. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    not really because your taking off very little.
    its common practice when striping cars for repaint to sand the paint til its about off with 40 grit, take the remainder off with 80, then smooth out any scratches from the 40 and 80 grit with 180 and 220.
    it sounds kinda stupid to be sanding bare metal, but after the 220 its sorta polished looking.
  7. XHitman396
    May 3, 2002
    620
    so if i were to sand it all out with 100 grit, then smooth it with 220, then use this metal treatment my buddy's giving me, do i need to prime it before i paint it? all i want is it to last 2 years and not rust, and am i supposed to seal it or something? thanks again..
  8. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    im not quite sure what the metal treatment is, but i would just use primer instead.
    you would get 2 years atleast out of it.
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    The metal prep that your friend is giving you is probably an etcher. It helps the primer adhere to the bare metal. You can get a self-etching primer if you didn't have this. I would recommend the etcher, primer (to seal the surface so moisture doesn't get to the metal) and then paint it. I know you say it only needs to last a couple of yrs, but it will probably be longer than that.
  10. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    If you are going to Krylon it temporarity, Just scuff the exisiting paint real good with some scotch brite pads, and paint it with a flat or semi flat military color spray paint. I got mine from Jeep surplus (Earth Brown). It took 12 cans (2 good coats) and about 4 hrs. My whole truck was finally one color! It looks awesome. Also if you get srached up, just sand it down and spry it again. Its cheap qiuck and easy.
