ATTN mechanics: 1992 olds cutlass supreme: 3.1L to 3.8L swap
Discussion in 'The Lounge' started by R72K5, Aug 25, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i need ot know if a 3.8L will swap into the engine bay of a 92 cutlass supreme SL from an olds 88 car of almost the same year. i think 88
    will engine mounts and bellhousing be the same ?
    3.1L car:
    VIN: 1G3WH54T3ND347780
    Year/Make/Model: 1992 OLDSMOBILE CUTLASS SUPREME S
    Body Style: Sedan 4 DR
    Engine Type: 3.1L V6 FI
    thanks for anything at all, pleasepost anything at all that you may know about this, the 3.1L blew upand i have access to the running driving 3,.8L car that was vandalized/totalled physically just the other night, so...
    thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    anyone ?
    where may i find out maybe ?
    thanks for anything at all, anything!
    thanks /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    apparently they only put 3.1 and 3.4 in these cars, hmm..
    is this true ?
    what all years were MPFI like this 92 ?
    will a 3.4 readily swap in place of a 3.1 ?
    is chevy v6 FWD bellhousing same as pont olds buick bellhousing ?
    thanks for anything
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I don't think so....
    The 3.1 is a stroked version of the older 2.8 and so it's a 60* Chevy V6.
    The 3.8 is basically a Buick motor - which is a 90* V6 and shares a bellhousing bolt pattern w/ Olds and Pontiac (B.O.P pattern).
    If this is the case, the motors have virtually nothing in common.... /forums/images/graemlins/frown.gif
    Marv
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i was told anything under 4.3is 60 degree, well besides the 250 and 230 and such
    IE you cannot mount anything under 4.3on a v8 or strasight six bellhousing
    so what gives ?
    thanks
  6. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    so what gives ?
    Not true... The Buick 3.8 is a 90* that dates back to the early sixties when it was available as a 225 cid odd fire in Buick Specials. But again... it's not the same bolt pattern on the bell housing as the chevys...
    Marv
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Agreed. (allthough, I'm not sure about the bell-houseing bolt pattern, not my area.)
    Marv, Is that you dude ?
    What ya' lost ?
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok, well its 60 degree bolt pattenr anyways, i dont think FWD ones are same dela as RWD ones, i dontthink the olds 3.8 are the same deal as the old buick v6 things, AND according ot junk yards, ALL the FWD 3.8's of all the divisions of GM are same thing and bolt in same
    also soemthing is misunderstood here somewhere or other, the old 3.8's were ued in the old RWD malibus and such, they are different than the 80s and 90s FWD stuff.,
    anyways, does the 90's MPFI 3.1L have interference head to pistion design or not ?
    imight just need to only replace timing set and be good to go,i assume that 3.1 bend valves when timing set breaks
    is this true or false ? i was told false a minute ago over on GM forums http://discussions.gmforums.com/showthread.php?p=369245&goto=postid
    thanks
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
